Bdiazair wrote:Not really sure what ones view out the front window or what tire touches down first has anything to do with flying the airplane... unless you can't fly the airplane.
The OP lives in Alaska, which means more than likely at some point, he's going to try landing off airport....gravel bars typically have obstacles, regardless of how smooth the bar itself is....so being able to see over the nose helps.
As to which wheel touches first, with the same size tire on all three, you've set yourself up to land three point, and sometimes its really tough not to put that nose tire down at a little higher speed than you'd like.
I've seen a number of 172s with bent firewalls and some with the nose gear taken right off. Of course, that suggests poor pilot technique, but having just an inch or two extra clearance between that nose tire and the surface at a "normal" landing attitude really helps.
The 206 I flew for a few years was equipped with 8.50s on all three, and it was a real pain in the butt to avoid putting that nose tire down too soon/fast. Replaced the nose tire with a 8.00 x 6.00 and it made a world of difference. I didn't land anywhere different, but it was just a lot easier to protect that nose gear during landings.
