TomD wrote:Correct me if I am wrong, but as I read the ADS-B regs pretty much everywhere you are required to have at least a mode-C transponder you will be required to have ADS-B out.
That being the case, if you don't want to be followed just turn off the transponder. Granted this makes the airspace somewhat less safe.
Bonanza Man wrote:TomD wrote:Correct me if I am wrong, but as I read the ADS-B regs pretty much everywhere you are required to have at least a mode-C transponder you will be required to have ADS-B out.
Not legal, if you have it it has to be on. If you want to be anonymous then go the 978 route that has an anonymous mode.
How does 978 UAT do it differently? The 978 UAT rules allow for an "anonymous" operating mode for aircraft flying VFR, and most avionics manufactures' equipment support this (but it's advised to check first - it is the manufacturer option to decides if they want to include this feature). If the option is available, it can be enabled during the installation. When the aircraft is on the ground and during the first few minutes of flight (so ATC can establish a track), the 978 UAT sends out the ICAO code and Flight ID. After that, as long as the squawk is set to "1200," the 978 UAT automatically scrambles those two fields using a random encoding scheme. ATC is able to maintain track, so you are safely "in the system" but other aircraft and observers on the ground with receivers (like "Flight Radar24") loses all of the identifying info - with no way to correlate it back to a specific aircraft or aircraft owner.
TomD wrote:Not legal, if you have it it has to be on. If you want to be anonymous then go the 978 route that has an anonymous mode.
I was not aware that one had to have their transponder on outside of required airspace. I am aware of the requirements for Class B etc. but not in the boonies.
Timberwolf wrote:TomD wrote:Not legal, if you have it it has to be on. If you want to be anonymous then go the 978 route that has an anonymous mode.
The FAR states in "controlled airspace", which class E is technically controlled. CamTom is right that class G is the only one where it can be shut off.
BKK- Good find on the ADSB info
mtv wrote:It is worthy of note that a significant percentage of midairs occur within class D and C airspace.....i.e.: under positive ATC control.
§91.215(c) Transponder-on operation. While in the airspace as specified in paragraph (b) of this section or in all controlled airspace, each person operating an aircraft equipped with an operable ATC transponder maintained in accordance with §91.413 of this part shall operate the transponder, including Mode C equipment if installed, and shall reply on the appropriate code or as assigned by ATC.
Cary wrote:FWIW, there's very little G space left in the country. For all practical purposes, that means that if you fly, you're in controlled airspace.
CamTom12 wrote:Cary wrote:FWIW, there's very little G space left in the country. For all practical purposes, that means that if you fly, you're in controlled airspace.
I have to disagree on a technicality here. There's TONS of class G in this country. However, there's not much of it above 1,200', which is what I'm pretty sure you meant to say!
DENNY wrote:So if I had a transponder, but did not maintain it in accordance with the regulation would I have to turn it on???
This all started with the capstone project in AK trying to keep the bush pilots alive. For them it has been a great system not perfect but a lot better than the old days. The big problem is once they found out it worked they should have made it space based not ground based. I am sure funding was an issue and FAA just had a bone they would not let go of. Now it is just a mess and will stay that way until somebody decides to clean it all up. It may just go away one day to be replaced by a space based system, Cheaper in the long run for all except you will need more tin foil because than they will truly see all.
DENNNY
