UtahMaule wrote:Have you tried it on top of your wing yet? Is there a valve so you can get it up and ready before the fuel starts?
OregonMaule wrote:UtahMaule wrote:Have you tried it on top of your wing yet? Is there a valve so you can get it up and ready before the fuel starts?
I just got 2 of them. No valve. Good nozzle. With out the nozzle 1.5" opening. The jug collapses as it empties so it should dump fast. My plan is to attach a longer clear hose to the nozzle with a 1/4 turn valve and a 90* end. With this setup I should be able to lay it on the wing and open the valve in a controlled manner.
Terry wrote:I would suggest putting one end of the bonding wire in your mouth (for good continuity), 3 raps around the neck of the jug and the other end in your fuel tank.
.dlhanst wrote:"turtle pac" makes some nice ones also.
Re: Alaska Bushwheel gas "can"
Postby kevbert » Wed Jun 08, 2011 7:16 pm
$75, ouch!
