IrishmanPDX wrote:Just a few not so quick answers to the questions about this video, unfortunately there is no simple quick answer!
1) Is this all MAC compatible ?
Yes.... However the video you saw was created using a paid version of Adobe Premier Pro, so there is a cost involved. You also need a pretty powerful MAC or Windows PC to be able to stitch and then edit the video. You also need a bit of video editing knowledge to be able to work with the footage.
The good news is that GoPro have released new software for the Mac that allows you to reframe (pan, zoom, tilt) your 360 footage for free that works with both the GoPro Fusion and the newer version of the camera the GoPro Max.
2) Are the video file sizes huge since you're using two cameras in one housing ?
With the GoPro Fusion, it is indeed two camera's in one housing, so you have files for the Front Camera and files for the Back Camera and each has it's own SD card. The file sizes for each camera are the same as a regular GoPro, there's just twice as many of them. However during the "stitching" process (joining the back and front camera footage into a single 360 spherical video) that increases the size of the files vastly as they are uncompressed video editing standard files. To give you an idea of the file sizes you would be dealing with:
Entire Flight Time 1Hr 35Mins
Entire File Size: 139GB
Stitched File Size: 321GB (and this could have been larger if I had exported in ProRes)
Time to stitch: (Depends on how powerful a system you have, but the average could be 2 mins per 1 minute of footage).
Edited File Size: 1.36GB
The newer GoPro Max only uses a single SD card and does it's stitching in Camera. So this is a huge workflow time savings, the downside is the bitrate is nearly 30% lower than the Fusion and for video editing on a Mac, you still need to convert the files for use with a video editor and this could take quite a bit of time.
3) What do you really like about this outfit ?
The ability to Pan, Zoom, Tilt the footage in post production. This is far better than using a fixed view camera. Have you ever been flying and seen something out of the corner of your eye and thought "I hope I caught that on camera" only to find out later it was JUST out of view of the camera lens? Well not a problem with a 360 Camera as you can turn the view around later on. Before shooting in 360, I had tried buying a 3 camera mount that attached to a wing strut. So basically to get certain shots, I would have had to use 3 different camera's, work with 3 different video tracks and this would have been 3 times the work. Now I can use a single camera and make it look like I have a multiple camera setup. Also the stabilization when shooting in 360 is fantastic. With the GoPro Max it's done in camera, with the GoPro Fusion it's done during the stitching process. Either way, it's amazingly smooth stabilization. All the footage you saw was shot at 30FPS. if you did that with a standard GoPro you'd see nothing but Jello in the footage. Not so with the GoPro Fusion.
GoPro's mobile app can also be used to edit short small clips very quickly if you have a compatible phone. The app used to be horrible however this year they really did put a lot of effort into updating the app and making sure 360 video was supported on it and I have to say, it's now pretty darned good and it just keeps getting better. So they really made some good choices by concentrating on that.
GoPro also recently updated their VR plugin for Adobe Premier Pro. Good news is that it's fantastic and has some amazingly useful and powerful bells and whistles while being even simpler to use.
4) Anything you don't like about the camera or software ?
Oh yes, shooting 360 has it's disadvantages. Overall, it's a much lower resolution than shooting with a standard GoPro. When you think about it, with a standard GoPro, you have a much reduced FOV that's being filmed in 4K. With the GoPro Fusion and GoPro Max you're shooting in higher quality (6K reduced down to 5.6K once stitched) but that covers an entire 360 degree sphere. So the same FOV as a standard GoPro could actually end up being less than 1080P. This means that the 360 footage is great for up close shots, but shots of the horizon or anything far away isn't going to look as clear or sharp.
It takes a lot of time to get the footage prepared with the Fusion due to the fact that stitching and stabilization needs to be done on your PC or Mac before you can edit the footage. So you need a lot of hard drive space, a very powerful PC or Mac and spare time. I found that with large file sizes like this it was best to prep the footage and let it stitch overnight so it was ready the following day.
Currently the best way to work with 360 footage is to get and Adobe Subscription so you can use their video editing software which allows for 360 editing. This will set you back a minimum of $24 per month. So it's an ongoing cost. There are alternatives out there, but the reliability and quality isn't there yet. GoPro does have free software for the Mac and there is a PC version being worked on, but I haven't used either yet so I can't comment on they work or what the quality is like, but I'm guessing it will be as basic as their mobile app.
When working with the footage and editing it, you still need a pretty powerful system, you also need a very fast large hard drive. Working from your primary drive is always best as external USB drives tend to be a lot slower than people think. Their access times can be much slower, they could also have built in sleep functions to preserve their durability and this all affects working with your footage.
If you want gauges on your footage that's another cost. Currently only the GoPro app has the ability to add gauges to 360 footage. So if you want gauges on your 360 footage on the Mac or PC, you need to use another program to create them and it's a bit of a chore to insert them into your footage.
The new Plugin that GoPro released for Adobe Premier Pro only works with Premier Pro 2019. Adobe recently upgraded their editing software to a 2020 version and it's caused issues with the plug in. So GoPro is working on an update but until it's ready you need to edit with the older version of Premier Pro (which is an issue but it isn't a huge issue).
So I hope that answers your questions. I know it was a bit of a slog but just wanted to make sure that you have all the relevant info. If you have any further questions or need anything more in depth, feel free to ask. My overall thoughts are that with shooting 360, you get back exactly what you invest into it. The more you invest (money and time) the better the return.
Thank you so much for the detailed information. I've been an amateur photographer for many years and have a lot of videos taken while flying full scale and my drone footage as well. With recent retirement I want to start editing my collection of footage.
If you don't mind another question, I would be interested in what you would consider "minimum system requirements" for editing mostly 1080p video, and the occasional 4k video for personal hobby use. Processor speed, number of cores, how much RAM, how much internal storage space, etc would be very helpful. If you have time and don't mind typing, perhaps a "Good, Better, Best" of system requirements. I am MAC based and would be using a laptop due to living in a camper while traveling if that matters.
I would assume the output from the GoPro Fusion or MAX would require the "Best" equipment ?
Thank you !
