Lately I've noticed that it takes a brief rpm increase to about 1800 to get my alternator to output. The other day I noticed in flight around 2400 rpm that my battery was discharging. I changed rpm as much as I could in level cruise and no dice. So I landed and it started charging again.
I checked my wiring and found and fixed a loose connector this weekend when I changed my oil, but then on my leak check it requires an rpm increase to start charging again.
What should I look at next in troubleshooting? Does this sound like something you might have seen before?
I found this video very helpful.. I trouble shot it in 10 min and replaced the alternator with a Plane Power Alternator.
