Looks like one fatality during a wheels down water landing.
https://www.ktvz.com/news/plane-crashes ... 1088470139
Best wishes to all involved.
1:1 Scale wrote:Sounds like the engine wasn't making power on takeoff From the airport, and they weren't able to get the gear up before trying to put it down on the river.
He just had the floats installed within the past month or so
Karmutzen wrote:Icon A5 just tried a landing with the gear down in a lake near Kelowna, BC. Flipped, but both got out ok. I flew amphibs for years, always worried about the gear being in the right place for the surface. Even confirming switch position isn't enough, after a friend flipped his when the breaker popped on the hydraulic pump.
https://livestream.com/accounts/21058359/events/8729054/videos/192979812/player?width=640&height=360&enableInfo=true&defaultDrawer=&autoPlay=false&mute=false
qmdv wrote:1:1 Scale wrote:Sounds like the engine wasn't making power on takeoff From the airport, and they weren't able to get the gear up before trying to put it down on the river.
So would a landing on rough terrain be better for a gear down landing?
G44 wrote:qmdv wrote:1:1 Scale wrote:Sounds like the engine wasn't making power on takeoff From the airport, and they weren't able to get the gear up before trying to put it down on the river.
Probably so, not in all cases, but in most.
mtv wrote:I’d still rather be on land, with gear down. Underwater egress can be very difficult.
Also, in amphib on takeoff, gear should come up as soon as airborne, no matter how long the runway.......positive rate, gear up.
Sad deal.
albravo wrote:mtv wrote:I’d still rather be on land, with gear down. Underwater egress can be very difficult.
Sad deal.
Mike, I've always had it in my head that if I was going to ditch on a flat surface I would like the gear down but if I'm going to fly it into the side of a mountain I would leave the gear retracted to penetrate the trees more cleanly, just using the floats as crumple zones. Is that a hard rule for you-- if landing on land, gear down?
I have about 60 hours on my amphibs now and have had one time the gear wouldn't come down due to a short on the hydraulic pump wire. The hand pump sorted that one out. My system is switch first, then lights, then indicators on top of the float, then mirrors. Then I either say "Lights are brown, gear is down, I'm landing on the ground." or "Lights are blue and water is too."
I'm lucky I've never flown retract so I don't have muscle memory that says gear must always be down before a landing.
Allan
