I have a Lift Reserve Indicator installed on my PA-28-140 and I like it very much. You can read an article about the LRI on wikipedia here:
http://en.wikipedia.org/wiki/Airspeed_i ... _IndicatorI chose the LRI over an AOA meter for these reasons:
The LRI is fully self contained and is sensing air-powered and can be installed in certified aircraft.
It can be installed without a 337 provided that no other systems or structures are altered. No electric, not pito-static, no structural holes.
The LRI encompasses both AOA and Impact pressure to drive the readout and thus provides the pilot with more than just AOA information.
Once installed, and adjusted by the pilot, the LRI accurately measures the Potential of Wing Lift above the stall at all times and all flight conditions.
The LRI is spring-loaded towards the stall, and is more sensitive the closer to the stall you are flying.
One of the posts pointed out that mounting an AOA sensor far out on the wing could give false information during critical maneuvers. Mine is mounted at the left wingtip and works very well. I have been able to do steep slow turns below the white arc without any trouble. Any control input that changes AOA is displayed immediately. I have also climbed with two people and 2/3 fuel at 40 MPH, but the warmer it gets, the less reserve power I have and the less likely my airplane can stay on the low end of the LRI during high AOA climbs. My Cherokee 140 just doesn't have that kind of power when it gets hot outside. But when it is cool? I have me a little HOT ROD!
Using the LRI well to those real short landings takes a lot of practice, and I get rusty with it if I don't fly a lot. Take-offs are another story. While you can climb out from the center of white arc, I found out that I need to be rolling in the green before lift-off or the aircraft might not fly out of ground effect. One notch in the green is plenty for pulling into the white, but I found I can initiate a good postive steep climb by just holding and maintaining the green/white edge on the takeoff roll. When I am 100 ft over the trees I lower the nose and add airspeed, which by this time is around 40. I know I could experiment and get better, but I've been having too much fun to get that serious. Our Airport is at 85 feet and is 2940 feet long. On a 40F day I can make 1000AGL before crossing the end of the runway! I have done it!
I hope this helps. Pete
