Early days but looking to also embark on a 185B that has not flown for nearly 10 years. I am keen to keep everything as original as possible, including the -470 engine. Avionics the emphasis is also original panel with a new COM and an IFR GPS/COM. It has Mode C.
In terms of the near on 60 year young airframe I would get the shop to look at: control cables, fuel lines, fuel bladders (it is a 65 gallon ON/OFF fuel selector model), wheels/brakes/tail wheel, and look carefully at the stabilator trim. From the inspection hatches it appears corrosion free but the wings will be boroscoped - theory there should be no need to take the wings off? Tail feathers would be removed for inspection and overhaul of the trim system. Query whether a gear box strengthening is now regarded as a must have. Tailwheel lock seems overkill? Not installed on this sample.
Engine: it is about half life but obviously has not run in years, nor has it been pickled. Magnetos would be overhauled and IRAN carried out. New battery but not planning to replace the generator with an alternator. Propeller is two blade and in good condition but CSU would be overhauled. Fuel pumps would be overhauled/checked.
Electrics: see above, thought is junk the old 170B x 2 plus ADF and replace with a GNC225 COM and either a GTN650 or 635 or second hand KLN94. Wiring to be replaced. Replacing the gyros with a G5 is a thought from a weight saving/maintenance perspective.
Interior: BAS four point harnesses for front row, and upgrade seats.
Logs are reasonably complete, some gaps in the early years but no recorded incidents other than a runway over run 25 years ago. Paint is OK, in due course it would be restored to an original 1962-1963 scheme.
My philosophy is use budget for flying, this isn’t a working airplane.
However any missing potential updates that evry 185 gets today? No plans for a -550 or a Sportsman mod, although the latter might be considered when and if the aircraft is re painted.
