Backcountry Pilot • Are y'all landing tri-gears off-airport?
26 postsPage 2 of 21, 2
Re: Are y'all landing tri-gears off-airport?
Yes, I land off-airport with a tricycle gear aircraft. Very carefully. Which is also how I land off-airport with taildraggers.
Troy Hamon offline
Aircraft: Piper PA-22
OP, you need to define what off-airport means to you and post it here. Then you can get a more definitive and valuable response. Half the places I fly you'd need a 42" Bushwheel on the front and 35's on the mains, the other half, except for landing distance, a big tire trike could probably land with a good pilot at the stick.
Barnstormer offline
I thought this trigear was a steal. Not sure how capable it would be "off airport", but I've seen some videos of a guy in an old 172 that lands on some crazy stuff....
http://airplanemart.com/aircraft-for-sa ... ark/13880/
Airplaneflyer offline
Aircraft: Cessna 170
Really depends on how extreme you want to go 'off airport'. Ok yes a tail draggers are personally the better aircraft in my opinion however that's not to say there isn't plenty of off airport spots you can't go in a nose dragger. You just won't be able to go everywhere.
Biggest thing really is what aircraft can you get the most out of? If you are not a very confident tail wheel pilot but can make a nose wheel sing, then do you that is the best off airport machine. As I said, you'll just have to be a bit more cautious as to where you go
DrifterDriver offline
I would take a trike over a TW on the beaches any day, especially beaches with a steep slope to the water and a off-shore breeze blowing, or, woopty doos, or even worse both at the same time.
Headoutdaplane offline
www.belugaair.com
Today at Kaguyak was certainly no fun with the 185.
Sent from my SM-T310 using Tapatalk
Troy Hamon offline
