a3holerman wrote:I agree NO relay, just another failure point.
What I have on my 185, that I had not seen before I bought it, is two avionics switches mounted next to each other. They are simply wired in parallel in case one fails. Simple and cheap.
T
hotrod180 wrote:I've never cared for avionics masters. In fact I've removed a couple from previous airplanes but I left the one alone in my 180. It made sense when someone explained to me that it might save a lot of wear and tear on the little (and expensive) on/off switches on the radio & transponder. Plus, it is kinda nice to just throw one switch after start-up and have radio txp intercom and now my electronic horizon all come on together.
Mine is a standard Cessna pull switch wired off the buss, and wired to separate circuit breakers for com txp gps & horizon.
