Superdan00 wrote:I currently also have the exact same problem, changed valve core also and that didn't help. I've been meaning to search for the leak with soap and water. In the mean time I put an air compresser in the hanger.
I too have an air compressor in the hangar, and it works great to top off before I go flying. But when I'm out camping and my tire goes flat in the field, it isn't convenient.
soyAnarchisto wrote:Yes it is. Although since the acquisitions by Airframes Alaska - i don't see it in their online store any longer. But, you can get it at any bicycle shop - or order directly online.
I'd call ABW and get guidance on the amount to add - since it's a function of the inside surface area of the tire. Too much or too little is probably not good. Its added through the valve stem with the core removed.
I spoke with Airframes Alaska today. They told me that "tires are made of rubber and can leak". They recommend trying the Stans Notube and they do sell it. I called my local bicycle shop and they too have some so I will just run over there and pick it up. I was told to put about 1 ounce into the tire and to add more every so often because when it dries out, it stops working.
Airframes told me that if my tire is out of warranty, that they would give me a discount if I were to need a new tire.
