Summer holidays continue in New Zealand.
This was an especially tricky spot, by my personal standards. This was a 300ft one-way landing on a rocky bar, you can almost see the whole rollout area in the picture, plus the dead-end trees in front of the plane. The aircraft is sitting where it stopped under braking, to give you an idea how tight the bar is. To be honest, I missed my mark and landed about 40 feet deeper than I needed to. Also, the rocks on the bar were quite large and unevenly patterned at the far end. I was not that impressed with my judgement from the air.
I've been pushing the limits recently, and grown a little more comfortable with these very small spots... some of the time. Unfortunately, rougher shorter spots tend to throw rocks into the tail feathers. This was one of those days, we punctured the fabric in two places with one rock. Field repair... But we are accessing some pretty neat sections of river, there sure are a lot of trout there.
This is another little spot where I used absolutely full braking power - but we had room to spare in the end. Again you can see almost the whole landing run in picture. It should have been a video...
This one was quite smooth, fortunately. It's hard to assess all the spots perfectly from the air. Some times you can see the grade of the rocks isn't that large, but upon landing you find out the rocks are patterned in such a way that some stick out and others lay low, making for a rough landing.
This spot was also really tight (see a trend developing?) and I needed to use the water to get out again. I was loaded with three people and full tanks this time, a heavy load for a gravel bar less than 300 foot long. It's been very hard to find a situation where the IO-540 powered Bearhawk lands as short as it takes off, but somehow we're easing closer and closer to that situation.
Using the water was a big moment, for me personally. I haven't used water before, because I've never
needed to before, and I've never practised it as a result. I have read enough about "how do I hydroplaning the wheels" to know what to expect though.
What surprised me the most, was how much give the water had. I could feel the wheels go deeper as I checked the stick forward (to check I really was on the water), then spring me back into the air. I probably only used two or three plane lengths of water, and that was more than I needed, but still a first for me.... baby steps are good, because they don't tend to end badly!
