Backcountry Pilot • Bearhawk in the Backcountry
194 postsPage 4 of 101, 2, 3, 4, 5, 6, 7 ... 10
Re: Bearhawk in the Backcountry
hotrod150 wrote:
Battson wrote:........Gradually building up to bigger rocks, still at 14psi with bead lockers (no slippage).
From this comment & your photos, I assume you're running 26" Goodyears? How abut a description and/or photo of your "bead lockers"? Thanks.
You got it.
Here's a little "how-to" for running your Goodyear / Desser tundra tires at very low pressure, without risking the dreaded rim creep causing a flat tire. This is an unapproved mod, so it's applicable to homebuilt aircraft only.
The tire's bead is thick and strong, but relies on air pressure to hold it firm against the rim. When you run low pressure, say less than 20psi, very heavy braking torque can cause the tire to gradually slip on the rim.
To stop this happening you want to lock the bead of the tire in place, so it can't move. Some people recommend contact adhesive. One way to do this mechanically is as follows.
I know this works with Grove / Cleveland wheels, check your measurements if you try a different brand. I have tested this over and over by locking the wheels on gravel, dirt, grass, etc. There hasn't been any slippage at 14psi with a 2700lb [MTOW] aircraft.
Start with disassembled wheels, drill to hubcap screw holes right through, without removing or damaging the factory threads. There's no need to add extra holes, three is plenty.
Tap the threads right through, they are 8/32 threads on the Grove wheels. Clean up any burrs or sprigs with your countersunk reamer.
Measure the depth of the holes carefully, mine were 7/16". Select screws long enough to protrude about 1/4" into the bead of the tire (for a 26" Goodyear). For other tire types - check your bead thickness first!! You want the screws to bed-down properly into the bead, not just scratch at the surface. But the screw should not dig so deep that they could poke right through, and interfere with the inner tube!
Reassemble your wheels and tires. Careful to torque everything correctly, etc... assume you know the process back-to-front if you're working on your own aircraft. Inflate the tires.
Sharpen your measured screws to a point, without shortening them, and screw them into the tire. This shouldn't take a lot of force.
All finished (hubcap removed). Don't forget to get IA sign-off if you don't have the repairman's ticket!
Notice the "slippage" mark painted opposite the valve on the wheel-tire interface. This allows me to check for rim creep with the hubcap installed, which I do every preflight as a matter of course. I highly recommend doing this regardless of whether you have bead locks, a flat tire is no fun.
I hope that's helpful!
Battson, thanks for the witness mark tip on the rim/tire assembly seen it before but never thought to apply it to the wheels.
Beamer pilot offline
Beamer pilot wrote:Your thread is making me re-think my trip to Australia, great looking countryside in NZ.
We're close - only 3hrs from Sydney (AU) to Auckland (NZ). If you're coming all this way... :)
If you did find yourself in NZ, be sure to post a message beforehand - we will sort you out with some BC-flying.
If you find yourself in NZ, be sure to post a message beforehand - we will sort you out with some BC-flying.
You're on when the time comes..
The spring season of bow hunting has been keeping me busy, but we're still doing some flying:
I should have taken some video of this landing, as this was a real doozey of a spot. The ground is uneven with some brush to roll through. There are a couple of very large mounds about 300ft in, at the middle of the strip, which made it hard to stay straight down the wheel tracks. The surroundings were "unforgiving" if I had ventured off track by more than a few feet. The "good bit" of the airstrip is slightly narrower than the Bearhawk's landing gear.
It took me 7 passes and 3 drags to get confident that I had the room and safety margins I wanted, before I applied the brakes. The strong prevailing wind meant landing downhill, which prolonged the difficult roll out.
Here are a couple of other short from the weekend, just an easy local spot this time.
Spring / summer Christmas weather - more rain in the distance #-o
Here are a few more snaps from recent flights. The last 25hrs has gone pretty quickly, wish I had a few more action shots to show for it....
Out fishing with family.
Joy-riding and stopping in for a paddle on a hot summer's day.
Scenic flights with a mountain valley landing. Wet grass means sledging the tires the whole way down the airstrip on a dewy morning with a full load aboard!
Flying in for a quick hunting trip at last light. Got a deer too :)
Here are a couple more scenic snaps
My lovely wife! (not the best photo though #-o )
Here's a better one!
An early morning trip with friends, this one's the approach about a 1 mile final. Lots of windshear. Airstrip is on the hard left-hand side of the valley, with a dog-leg turn on short finals.
Goin' hiking with friends
Moody weather on an autumn's morning
Here's a little video of us landing high, above the bushline, for a weekend bow hunting deer.
Photo from same location
Here are a few snaps from a recent trip down the river to the seaside, there is a roughly-filmed riverbed take-off video to match.
Great pictures, you live in an awesome place to fly!
Amazing!
Pretty awesome!
soggyc offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... KhvYFzCT8z
Here's our latest - and possibly best depiction yet - of backcountry exploits in the Bearhawk in the Southern Alps, New Zealand.
This captures the spirit of accessing a variety of backcountry landing places for fishing, hunting, or just for flying's sake! Some of the landing places are as short as 500ft, although the Bearhawk doesn't really need that much room... :D
I hope you enjoy it:
Thanks so much for sharing that. You've probably just cemented the kit I'll be ordering in the next 10 years!
Wow, amazing country, what amazing scenery. Very nice plane, too[emoji41].
blackrock offline
Aircraft: Bearhawk
Very nice. Beautiful country. And that Bearhawk really gets with it! But man, treat that plane to a set of 31s - you won't regret it.
North River offline
NICE! Beautiful Country, Nice Airplane Excellent flying!
bowie offline
I like the slow apparent rate of closure on the approaches. I don't like a wing down near the ground. Rudder (wings level) turn or energy management turn. I saw a good energy management turnaround in the valley.
Awesomeness [emoji106][emoji106][emoji106]
Skalywag offline
