Pretty basic question, but what's the go to alternator for the O-300D on a 172? Is the B&C the best way to go?
Thanks
David
wannabe wrote:What year 172?
It seems that there are "stock" Cessna parts from some years that can go to other years. First step is a Ford conversion with old klickety klack regulator then convert to solid state regulator. Minor wire changes (jumper) as I recall.
Most B&C alternators do not seem to qualify for anything but experimental.
Chris C
daedaluscan wrote:I have a ford alternator and regulator on the shelf that my mechanic won't let me put on. He says they are the same weight as the generator and prone to oil leaks.
He says I should buy this one:
https://www.aircraftspruce.ca/pages/el/ ... altkit.php
SKYTRONICS JASCO. 6560-1 ALTERNATOR KIT
Sticking with my generator for now.
48RagwingPilot wrote:I've had the STC'd B&C lightweight alternator in my C170 for a year now and am happy with the performance.
A1Skinner wrote:48RagwingPilot wrote:I've had the STC'd B&C lightweight alternator in my C170 for a year now and am happy with the performance.
Did yours go in the original alternator spot? Is this the one you have?
http://www.aircraftspruce.ca/pages/el/a ... rs-462.php
whee wrote:A1Skinner wrote:48RagwingPilot wrote:I've had the STC'd B&C lightweight alternator in my C170 for a year now and am happy with the performance.
That alternative is driven by a vacuum pad. B&C makes a cool permanent magnet alternator that goes in the original location on the O300. It's only 30A but it looks great to me. I always wanted to install one on my C85 but never did. It has a great reputation.
48RagwingPilot wrote:....but one must cut the pilot shaft to install it (not as hard as it sounds).....
