PittsDriver wrote:Heading out of KSLC I'd go I-80. I'm out of U42 so I generally go Provo Canyon or up Big Cottonwood Canyon. Either way I usually return by the other just to change the scenery. Don't go up trying to buy cheap fuel.
Rich
Grassstrippilot wrote:I go through Weber, Ogden and North Ogden at 6500-7500 if the winds are light. Parleys you’ll probably want to be around 9K. 7500-9000 through Provo on a calm day should be fine. When I come through that area I’m usually already at cruise above the ridge line...9500-11500.
Cary wrote:Have you done any canyon flying? Do you have any mountain flying training? That makes a big difference. Time of day, winds, aircraft performance capability, all play a big part.
Not many airplanes have the climb capability to take either Provo or Parley's starting at only a couple thousand feet AGL. Get your altitude first and then you'll be much safer. Rocks are harder than aluminum.
CAVU wrote:There's no substitute for dual, but Sparky Imeson's book https://www.mountainflying.com/products/mfbr_info.html is still a fantastic foundation and will help you get the most out of mountain/canyon dual.
CAVU
