Battson wrote:Can you post a picture or a description of what's in your panel Cowdog?
I am really interested to hear the weight difference you mention there. I've talked to Mike about setup (he's been really helpful too!) but I would be very interested to know more about your setup as well!
Thanks for your help with my other questions![]()
P.s. Bob made our engine as well, boy did he try to talk me down from the FI....
Yea, Bob isn't an FI guy, but Iit's worth it in my opinion. I decided to do FI for LOP operations if I am on a 500mi leg somewhere. My thoughts have been validated by Georg on the quickbuild list. He is running LOP at 8000 feet. Here is what he says:
When I am on cruise altitude at or above 8000ft I reduce RPM to about 2150 and pull back my mixture to a fuel flow of about 10 Gal. In the meantime I can hear when the engine goes over to the LOP side. Depending on the altitude I can lean a little bit more so I am ending up between 9 and 11 Gal/hr.
Throttle remains full open.
With this setting I usually see between 120 to 125 Kt TAS. (the only speed which counts )
He continues with:
I recently accompanied somebody with a Piper with 180 HP and that airplane used 9 Gal/hr and was cruising at about 80kt. As wingman at this speed my IO 540 was burning 7.5 to 8 Gal/hr. LOP
That is absolutely fantastic speeds for that fuel flow. So much so that I'm thinking about omitting my aux tanks, but then again Ketch to Boeing Field is 650 miles.
Anyway, I'll take the weight penalty for FI, if I don't need to worry about carb ice, the stupid airbox, fuel flow at high angles of attack, and to have a trip computer that tells me how much fuel I'm burning (which is hard to do on the gravity systems and a 540)
