Black foam interior
This subforum is meant to organize Cessna 182-related topics.
Tue Jan 14, 2025 10:22 pm
I see quit a few 180's and 182 with the interior striped out and black foam glued to the interior of the cockpit. Does anyone know what foam is being used?
TriPacerPilot offline
41
- Aircraft: PA-22/20-150, PA-24-250 Turbo
Tue Jan 14, 2025 11:58 pm
DENNY offline
791
DENNY
Sound deadening and insulation.
2057
- Aircraft: RANS S-7
I would not stick anything directly on the interior skins. After 30 years, your future owner will feel the same.
48Stinson1083 offline
88
- Aircraft: Stinson 108-3
I used the adhesive backed stuff form AC spruce as well. I went with 3/8" on my 206. I left it all exposed and its been holding up quite well. I sprayed 3M super 77 glue on the panels to give the adhesive backing a bit extra to hold on to.
5218
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
Wed Jan 15, 2025 10:45 pm
Thank you all. My plane already has something installed and I'm trying to find material to repair a couple spots. I'll order some samples and see if I can find a match.
41
