Well that's encouraging. I've seen the turboprop but I don't know where you would put enough fuel for more than a flight around the patch.S-12Flyer wrote:There is a 701 with a 914 at a private strip close to me. The thing is an elevator. They hang 0-200s and 3300s on the 701's and they are way heavier than a 914. Horsepower is your best friend on high DA days in the backcountry.
Check out this turbo prop on a 701.
http://www.zenithair.com/stolch701/pic1 ... llage1.jpg
Emory Bored wrote:Well that's encouraging. I've seen the turboprop but I don't know where you would put enough fuel for more than a flight around the patch.S-12Flyer wrote:There is a 701 with a 914 at a private strip close to me. The thing is an elevator. They hang 0-200s and 3300s on the 701's and they are way heavier than a 914. Horsepower is your best friend on high DA days in the backcountry.
EZFlap wrote:The firewall, forward fuselage and nosewheel of the 701 was not really meant for the weight of a stock O-200. Something like 240 pounds with the OEM starter and generator. If you really lighten it up, by liberal use of Dr. Seuss' Calculatus Eliminatus, then maybe.
But the handling of a small and light airplane will be seriously affected by the weight, even if you got the weight down to 200 pounds. That is why the CH-750 has a different firewall and forward fuselage than the 701.
If you want light weight and power on a 701, take a tip from our recently lost friend Dirtstrip (who had this airframe/engine combination) and start looking into the Simonini 110HP 2 stroker, with some sort of EFI upgrade for reliability. 52 kilograms (114 lb.) with integral PSRU, starter, electronic ignition, alternator... and 110 HP. The combination of 110HP, geared prop for max acceleration, and 100 pound less empty weight would make this a rocket. Emory Bored once told me he's on the light side, so he could potentially win some free beer off of the nearest Carbon Cub owner![]()
The mfg's CLAIM is less than 3 gallons an hour at cruise. So let's chalk up a couple of gallons an hour extra for "brochuremanship", and we still get under 5 gallons an hour. Yeah, I know... it's a 2 stroke. Gotta learn how to operate it, learn it's language, learn how to not piss it off, etc. etc.
http://www.simonini-flying.com/victor2super_eng.htm#
GroundLooper wrote:Congrats, EB!
After riding around in a friends Savannah recently, I think you'll be pretty happy with the performance. They don't carry a lot but boy they get off the ground fast and land short. I think you'll find it a to be a great and fun little airplane. Just keep it light on the build as much as possible.
I seriously doubt you'd be disappointed with the 912ULS and the 914 will add weight... you're research may say differently.
rudderbash wrote:I just got a ch 701 kit that a friend was building but got cancer so I now have it and I am going to finish it. The one change I am going to make is to get rid of the leading edge slats and go with vg's. You increase your cruise and it has better control on STOL performance.
EZFlap wrote:rudderbash wrote:I just got a ch 701 kit that a friend was building but got cancer so I now have it and I am going to finish it. The one change I am going to make is to get rid of the leading edge slats and go with vg's. You increase your cruise and it has better control on STOL performance.
Congratulations Rudderbash !
Again, IMHO contact John Bolding, he has the correct airfoil templates to use for building the wing without the slats. It is different than just leaving the too-blunt leading edge of the stock wing with slats removed... what you do is build a specific no-slat airfoil.
Have fun building, please let everyone know how you're doing from time to time.
EZFlap wrote:I recommend the Light Speed Engineering electronic ignition. This costs a few bucks, but makes several improvements. You will get a 10 or 15% improvement in torque and horsepower. You will get a 10-15% reduction in fuel flow. These two things will pay for the ignition. Most importantly you will remove the weights of the magnetos, and will be able to remove the weight of the starter. Using the LSE ignition makes hand starting safer, easier and a lot less effort. This in turn will allow you to use a smaller battery and a much smaller alternator (or even no alternator).
Battson wrote:Those power numbers sound generous, given the fact that at high power setting the timing difference between mags and EI is nonexistant.... where do they claim the 15% power increase comes from? Is there a non-promotional, independant document which verified that improvement? I have often wondered about that but never taken time to explore it.
