Here is the fuse for the Bearhawk Patrol ( Sea Plane Edition)
I was reading about IAS vs TAS at altitude, and Vne with critical flutter speeds. Ken Krueger has this interesting article titled:
“Flying High and Fast: Another reason why more power is not always a good thing “
http://www.vansaircraft.com/pdf/hp_limts.pdf
Anyway, here is a BRS system for the Vans RV9 offered by Aircraft Spruce
http://www.aircraftspruce.com/menus/ap/ballisticrecovery.html
Empty Weight 1015 - 1057 lbs
Gross Weight 1600 - 1750 lbs
BRS for Vans RV9
Here is yet another link to another BRS source.
http://magnumparachutes.com/products.htm
Magnum BRS Systems
A quick search for projects or completed EAB aircraft with BRS systems (specifically back country type aircraft) did not result in much. I know the Just SuperSTOL can land/slam down almost vertically at about the same rate of descent as a parachute
Just Aircraft SuperSTOL
Anyone planning for a BRS system as part of their build?
