I agree with Eric, 800s are probably sufficient for 95+% of the
stuff you might encounter with a stock-engined 170.
I have 850s on mine via field approval, but was only honestly
glad they were on there maybe once or twice over the last
several years. I have a mounted set of 800s on Clevelands
I've been thinking of swapping out on there just to see how
much speed the 850s cost me.
While your there, check to see if you have solid axles (hollow/original
is fine for 170s operated on smooth turf or pavement with wheelpants,
etc.).
I have double-puck brakes on mine (also field approved) and agree
there's plenty of brake there, but I wouldn't have it any other way.
At least now, *I* get to decide how much brake is required for
the given situation. With the single-pucks on there, the brakes
could give up before I was ready for them to!
You can shop around (eBay, whatever) and get this stuff for 1/2
the price (or less) than new.
I forget which one (I think the Kenmore) but one of the 850 STCs
for C-180s prohibits the use of 3-bolt Cleveland wheels (you have
to use the later 5-bolt or 6-bolt wheels). There were apparently
some failures in Alaska of the 3-bolt wheels running large tires,
but if you don't intend to land on boulders all-day-long, the 3-bolt
wheels should do fine.
One final thought... I've heard more than one source say if you
increase the tire size (to something like 850s), you probably ought
to consider going with double-puck brakes as well, as the rotational
inertia is higher with the bigger/heavier tires, which tends to
erode / negate existing brake performance.
