CW
hotrod150 wrote:He said he liked it because it made it easier to crawl in and sleep in the airplane instead of messing with a tent.
Scolopax wrote:One significant factor that makes this installation unattractive is that the fuselage can no longer support the loads reacted through float fittings. You have literally created discontinuities the vertical frames of a few critical bulkheads on the left side of the airplane
I have never thought that loading/unloading my 180 was particularly cumbersome, but I've never tried to put a 55 gallon drum in. I regularly put three 29 inch wheeled mountain bikes and three people in (all wheels off and stowed in the extended baggage). The factory split seats are not very comfortable, but are really nice for loading/unloading, because the seat backs slide off with very little effort.
hotrod150 wrote:My new 1953 Skywagon has a cavernous extended baggage, all the way down to the belly since the battery has been relocated to the firewall. Unfortunately the 53's didn't have a baggage door, and no one's ever added one to this airplane. Loading the standard baggage area through the boarding doors isn't bad since it's got folding jumpseats, but accessing the extended baggage is strictly a crawl-in operation. I was admiring the baggage door on a friend's early C210 the other day. The floor of the baggage area is quite high, as all the monkey-motion RG apparatus has to fit beneath it, and so the baggage door is also quite high-- about where this 180 stretcher door is. It'd be nice to add something like that to my airplane above the ext bay.
mtv wrote:hotrod150 wrote:......it shouldn't be that big a deal to add a standard baggage door if you want to. Won't be insignificant, cost wise, but.... MTV
hotrod150 wrote:mtv wrote:hotrod150 wrote:......it shouldn't be that big a deal to add a standard baggage door if you want to. Won't be insignificant, cost wise, but.... MTV
The key words are in that last sentence. Think I'll hold off, at least until I get the rest of the airplane tweaked just the way I want it. I would be more inclined toward installing a door at the ext baggae, as shown on N185JY in Wagnflyer's post-- it would be much more useful for my airplane than a standard baggage door. Like I said, I can easily access the std baggage area with the jumpseats folded up out of the way.
hotrod150 wrote: Wagonflyer, I'm assuming that's your airplane. Is that an STC'd mod, a field approval, or what? I'd be interested in finding out more about it.
