Fri Jul 22, 2022 12:34 pm
Well, I'm pretty sure that the OP has already sorted this out, but in the interest of adding to the searchable knowledge database, here's how I did it. I wound up with a 520 oil pump, and have a mechanical tach. On teardown my oil pump was not reparable, a new 470 pump is pretty spendy, and my engine shop couldn't find an overhaulable used 470 pump, so on went a 520 pump. I dimpled my firewall by backing it up with a sandbag (A shot-bag probably would have been better, but you work with what you got) and working it inward with a rivet gun with a flush set. I used a set that had more of a curved face than most flush sets do. I made a fairly generous recess to provide better clearance for fastening the tach drive cable. You can, of course, deform it too much and get a split in your firewall. I don't recall exactly how deep the dimple is, but it's significant;y less than an inch. I got an old Cessna firewall from my local aircraft salvage yard and practiced my metal forming technique a bit before I went live on my firewall. The results don't look exactly stock, but they look better than some firewall modification's I've seen.
