C180 Governor Control Rigging
Is the rod end supposed to nearly touch the bottom of the governor at the full forward position? Tried adjusting the arm. Tried adjusting the length of the control a bit, but you really don't have too margin to move it back and forth. In fact, I needed to make it as short as possible, so the rod end is screwed all the way in.
C180_guy offline
488
No. It should definitely no touch. Control cables (Mix, throttle, prop) must hit their stops w/o interference. I have come across this on 180s before. You will have to remove material inside the swing of the bracket so that the entire swing arm can move further.
2340
- Aircraft: C180H / C170B
www.avthreads.com
You mean increase the curved 'track' on the propeller control arm? Or, oval-ize the hole where the rod end attaches?
C180_guy offline
488
Sat Jan 05, 2019 10:50 pm
Have you tried moving the arm one tooth on the governor?
Halestorm offline
956
- Aircraft: C-182E Pponk
Halestorm wrote:Have you tried moving the arm one tooth on the governor?
You mean re-indexing the governor arm itself one spline over. Thinking about that now.
C180_guy offline
488
C180_guy wrote:Halestorm wrote:Have you tried moving the arm one tooth on the governor?
Only if the fine pitch stop isn’t incorporated into the arm, that could screw things up.
Halestorm offline
956
Sun Jan 06, 2019 10:24 am
C180_guy wrote: Is the rod end supposed to nearly touch the bottom of the governor at the full forward position? .....
I don't see the problem here.
The key word of course is "nearly".
10536
