contactflying wrote:That Skywgnyqa, and something makes airplanes with washed out wings turn without rudder. Unwashed or unbungeed wings, Ercoupe excepted, will not turn without rudder. Flying the aileron at less angle of attack keeps funky ailerons working at slower speed, where rudder actually works much better, giving the pilot the dangerous impression he should bring the upset or down wing back up with aileron. This when he needs to stand on the opposite rudder to get the down wing up smarty and safely without stalling the down wing.
I know the washed out aileron is supposed to help this situation and it does; so long as somebody teaches the pilot to use lots of rudder to get the wing back up. With modern airplanes Dutch rolls to 45% bank are very helpful getting this point across.
Unless you crop dust, have a serious upset, or need a tight canyon turn, you don't need to use lots of rudder to get the wing back up. If you encounter the need, only rudder will make it a comfortable and safe return to wings level
Jim,
I almost started a new thread to hit this but I wanted my response in the same place so that someone searching in the future runs across both posts in the same thread.
You may confusing washout, which is a twist in the wing, reducing the angle of incidence from the root (highest AoI) to the tip (lowest AoI). The purpose for washout is to ensure the wing root stalls first, allowing for aileron authority near the unstalled tip of the wing.
What you're thinking about are differential ailerons or Frise ailerons. Both do different things but for the same purpose: reducing adverse yaw.
- Differential ailerons have a larger up travel than down travel. This increases the drag on the descending wing, reducing adverse yaw.
- Frise ailerons have an offset hinge, so that the leading edge of the raised aileron extends below the bottom surface of the wing, increasing drag on the descending wing and reducing adverse yaw. These ailerons also create a slot on the lowered aileron, re-energizing the boundary layer and potentially increasing aileron effectiveness on the rising wing at high AoA.
I'm not sure that a twist (washout) in the aileron would reduce adverse yaw on its own.
Either that or I'm completely confused about what you're talking about.
/thread drift.
