Backcountry Pilot • C206 Extended baggage Why no option exists.
19 posts • Page 1 of 1
Looking in the back of my 206. Im wondering why no company ever made an extended baggage option? the book lists a 36 lb O2 bottle back there. i'm sure the air conditioner weight is similar. Why not fabricate a tray above the avionics stack. and gain a bit of extra storage for a cover, first aid and some tools.
Anyone have any thoughts? Id really like to fabricate something like this, however it would have to be removable to maintenance.
https://selkirk-aviation.com/extended-baggage-kits/.
Screenshot 2024-07-15 at 9.03.50 PM.png (1.56 MiB) Viewed 2071 times
Cameron96 offline
Aircraft: C206 Turbine
Re: C206 Extended baggage Why no option exists.
I recently removed everything from that radio shelf, I have the oxygen bottle in the way though. I had the same question, I have to imagine it has to do with the radio shelf and the fact that a 206 can be easily loaded to the aft CG without much trouble as is. But that's purely a guess on my part.
CParker offline
Aircraft: 1979 TU206G
Finally got round to this project, added about 1lb after all deleted. Involved 3 6061 angles, ensolite insulation, carbon composite board. and lots of time!
Screen Shot 2026-09-29 at 9.32.56 PM.png (3.02 MiB) Viewed 1066 times
Cameron96 offline
another view
Screen Shot 2026-09-29 at 9.32.38 PM.png (2.6 MiB) Viewed 1066 times
Cameron96 offline
top secret design schematics
Cameron96 offline
This looks awesome. You did a great job!
I have looked into a similar mod for my 205. According to this thread:
https://backcountrypilot.org/forum/cess ... date-16571
there appears to be a guy out of ID that does a similar type mod. I don't have an avionics shelf back there that is being used so I would likely gain more vertical room. The thread above refers to a Selkirk STC for a serial number range of 206.
Josef offline
Aircraft: 205A
I've carried a LOT of stuff in 206s. I've honestly never found a need for more aft space. Loaded anywhere near the aft limit, the 206 will sit on its tail without a passenger or pilot in the front seats.
I can fit a flyrod in the 206 without breaking it down but the tip sits on the glareshield kinda touching the window wrapped in a tshirt . Extended baggage would be nice to make the long stuff fit better.
low rider offline
vail
Cameron96 wrote:Image
Are you a flying data center? That's a server room.
HAHAHA, 1 is backup Lithium Battery, the middle is a Transponder Traffic in, was installed many years ago. up in Canada most small planes still dont have ADSB so this helps, maybe in 5-10 years we can remove. Then ELT and Light box..
Cameron96 offline
mtv wrote:I've carried a LOT of stuff in 206s. I've honestly never found a need for more aft space. Loaded anywhere near the aft limit, the 206 will sit on its tail without a passenger or pilot in the front seats.
when all 6 seats are in there, I got no room.. I bring a First Aid, survival kit, warm clothes, a number of life jackets, and a tool kit.
the dream is 6 people, and 6 overnight bags without having to put on your lap. W&B allows me, just not space.
a belly pod wont work with the turbine exhaust and going back and forth from floats every year..
Cameron96 offline
I got a fieid aproval back in day for an aft baggage on a 206.
It was an extended box with a door hinged across the bottom. The faceplate picked up the edge of the aft compartment frame with a series of nutplates and a latetal bar aft with a plate on each end that picked up about 8” each side of the the secind bulkhead aft. Its a little hazzy but I think it was placarded at 50#
A key feature was being easy to remove for each 100h/annual inspection via 10/32 screws/ nutplates around the peramater of the faceplate and a few picking up the aft lateral support.
I climbed about halfway down the tailcone at each inspection with my light and LPS2 at each insoection, no accesse to that handy panel there on the bottom with the long float ventral, and to be honest even on wheels I prefered to climb back there for good look cause.
Rocket
rocket offline
rocket wrote:I got a fieid aproval back in day for an aft baggage on a 206.
Rocket
Yes making it easily removable was the goal as well for the annual, Anchor nuts.
Cameron96 offline
I put the selkirk on in my 206 and it works great. Kinda wish it went back a bit further. I also dotn have any of the stuff in tha back of mine that you do, so that made it easier to accommodate.
low rider wrote:I can fit a flyrod in the 206 without breaking it down but the tip sits on the glareshield kinda touching the window wrapped in a tshirt . Extended baggage would be nice to make the long stuff fit better.
If it's just the fly rod(s).....
I've heard of people installing a "ski tube", it's just a tube that extends through the panel aft of the regular baggage area.
Either metal (light gauge furnace duct) or plastic (PVC pipe), with an end cap at the aft end.
I shoulda known....a fly fisherman...... :lol:
If it don't fit in a stock [-X 206 get a beaver or porter.
207 will not take any more weight but sure has the space.
I never liked them where a 206 is a good performer the 207 is a pig no matter what mods you do short of a turbine.
Bush Buggy offline
Or maybe use it as an excuse to buy yourself a new 7' 6" small stream rod. :D I now have a 6' 6" rod too...cute little thing.Takes all I got to chuck line very far though on open water.
Oh man , just what I need is another fly rod . I’ve had a life long situation of too many different sports. The amount of gear that is in my rotation is mind boggling, Sometimes I wish I still had the 207 but as was mentioned that thing was a pig when loaded. Not breaking down the fly rod is just me being lazy. Funny how I can spend a couple days packing up the 206 for a mission and when the last morning of the trip comes I can stuff the plane in about 20 minutes ( unpacked iced up tent and all in the pod) and be on my way .
low rider offline
vail
