C85 Alternator
If anyone within the BCP community is operating a C85 with an electrical system what alternator do you have installed ?
2329
I've installed a couple of the B&C's on 85's in Tcrafts. They seem to do a decent job. Nice and compact.
hardtailjohn offline
924
hardtailjohn wrote:I've installed a couple of the B&C's on 85's in Tcrafts. They seem to do a decent job. Nice and compact.
Thanks for the insight, compact is the key in my case. Do you recall which model it was so I can spec it out ?
2329
If my memory serves me, it's a model 200. They aren't a whole lot of amperage, but it seemed to work well and both were on a tight install, on Tcrafts with the short mount.
924
B&C has a couple options. Any of them would be a good choice. Their permanent magnet option is very compact and light weight.
3386
2866
I know a number of people who run a B&C starter on a C85-12 (or O-200) with the generator hole blanked off,
then just charge the battery (usually an Odyssey) between flights as required.
A friend of mine just installed a C85-12 on his Taylorcraft L2 with just this set-up-- all per the STC he used.
Dunno if this is an option but it might be worth considering.
10540
The best option by far would be the lightweight, low profile B & C alternator. To do this the airplane will have to be migrated to an OM C of A, that might be what happens once the engine STC has been completed.
2329
Sat Sep 21, 2024 10:59 am
I use one of these on a C85.
https://bandc.com/product/200g-alternat ... #regulatorLots of field approvals for them….makes for an amazing lightweight electrical system.
What are you putting it on? Bill at B&C provided lots of example approvals in lots of airplanes. I think there’s a T-craft STC floating around for them.
Amodel offline
20
- Aircraft: Cub
Sat Sep 21, 2024 11:03 am
Amodel wrote:I use one of these on a C85.
That's the one I would like to use, just need an STC for it on a Chief.
2329
