Looking to make new instrument panels for my 180k. Rather than reinvent the wheel. Does anyone have .dwg or .dxf files for the right and left instrument panels. Will cnc cut new ones. Installing G5’s and EDM 900.
skywgnyqa wrote:Looking to make new instrument panels for my 180k. Rather than reinvent the wheel. Does anyone have .dwg or .dxf files for the right and left instrument panels. Will cnc cut new ones. Installing G5’s and EDM 900.
propeller26 wrote:I would love the same thing for a 1977 wagon that we installed two G5’s in. If anyone has a lime on blanks for a 185 that would be great.
fredy wrote:I uploaded a zip file into the references tab in the 180/185 knowledge database. There are two dxf files (pilot and co). Of note, these are in a Cyclone 185, so they should be the same dimensions but use at your own risk.
https://backcountrypilot.org/knowledge- ... references
finished panel:
finished panel:
fredy wrote:no problem. I left the mounting holes off because I hand drilled to match the locations. Since mine is home-built, I doubt they'd do you any good anyways.
