Timberwolf wrote:. Just hate that these systems don’t allow users to create their own profiles to adjust for each specific installation, leaving marginal performance at times and not utilizing technology to its fullest extent.
btoms wrote:Aviation Consumer did a review of the two systems, Electroair and Surefly. They concluded that if you wanted lowest price, the reliability of electronics, and marginally better fuel economy, easy installation, go with Surefly.
Electroair will get you higher performance, much better fuel economy, better hot starts and all the other good things associated with electronic ignition. There is a reason CHT goes up with the Electroair system. You are burning fuel normally wasted by magneto ignition. You can choose to burn that fuel, higher CHT, or dial back the fuel and get the same airplane performance on less fuel.
CHT has not been an issue on my Electroair installation.
Bob
Timberwolf wrote:Look at the Surefly advance schedule and you’ll see that at 2700 rpm it can advance as much as 36.5 degrees. So if you put this on a Husky and were dealing with high DA, that is way above ideal timing for best power for a takeoff. All it’s going to do is jack CHT’s way up. Combine that with slow speed and low mass flow and you’re begging to cook a cylinder.
Timberwolf wrote:CamTom12, you are only understanding part of the equation. I disagree with your assessment that not taking MAP into account would result in not being certified. Please don’t tell magneto manufacturers that.
Timberwolf wrote:You’ve proven my point exactly. Not all takeoffs are with high MAP. Yes the Surefly takes MAP into account. But try taking off at Leadville in the summer. 36.5 degrees of advance is great for LOP cruising, but it is NOT where the engine needs to be to make best power ROP. Due to the power charts and standard programming in this type of system (PMag included), the timing is going to be way off the ideal setting. Which leads back to the Husky example. Way advanced timing at low speed with low cooling mass, ROP.
Timberwolf wrote:Absolutely. Gotcha on the EI specific. Makes sense.
In the grand scheme, people need to understand the operating principles behind these devices and though the manufacturer gives a WAG to accompany most scenarios, it doesn't fit everyone. Additionally these devices require power to function and a thorough analysis should be completed prior to deciding this is right for their aircraft. A step in the right direction, but still very constrained for the certified crowd.
180Marty wrote:btoms, I'm glad you joined into this topic. It sounds like you could go even leaner but do you figure you just slow down quite a bit so 12.5 is a nice sweet spot for speed and fuel consumption?
What plane engine are you running?btoms wrote:180Marty wrote:btoms, I'm glad you joined into this topic. It sounds like you could go even leaner but do you figure you just slow down quite a bit so 12.5 is a nice sweet spot for speed and fuel consumption?
I can get my fuel flow down into the low 11GPH range since the Electroair Electroni Ignition install.
I don't really push it though. Most of my flying is at 3K' over the shores of Lake Michigan and I'm not comfortable when the engine 'hiccups' while over the water.
I would estimate the Electroair system at the 23 square 3K' setting would save me about .5 to .6 gph if I chose to go that far LOP. At higher altitudes the fuel savings get much better approaching 2gph.
Attached is another G4 pic showing 23 squared at 11.4 fuel flow.
Bob
Interesting. We have no problem getting our pponk down to 9.5GPH at 6500ft on the 182. Had it down at 8.7 at 8500 and it was still running real nice. No significant speed loss, we were still trued out at 120kts which is book speed. Be interesting to see how it would improve with electronic ignition.btoms wrote:O-470-50 PPonk
Bob
