PilotMikeTx wrote:I'm interested in your plan on using Oratex on your certified aircraft. Have you talked to your FSDO about a field approval yet? Hopefully the STC will be forthcoming. Have you noticed if the 6000 is less transparent than the 600? I know you wouldn't need 6000 for the weight on a 140, but I don't like the see-through look that I've seen on other planes, at least not on a 140. I am going to soon ask my dad if I can borrow his 140 that I learned to fly in and restore it.
For the oratex 6000, I know a few 120's and 140's have been able to get field approvals for it and I have copies of their 337's. Considering I have at least 5 (that I know of) coats of paint on an older ceconite covering job, the weight savings will actually be quite large. Even on a light ceconite job, the savings would be almost 20 lbs, so with my heavy ceconite wings, I'm expecting maybe 25-30 lbs. I haven't seen it in person yet, so I don't know how translucent it will be, but from photos I've seen of the silver oratex 6000, it doesn't look very transparent. Good luck with your restore job, looking forward to seeing pictures!
