Can someone who has done extensive weight and balance work on a 170B assist me with this info request, thanks sincerely in advance.
I need to do some calculations for a tailwheel spring material selection (172 to 170 conversion project). As part of my STC conversion upgrade, I will be going from steel to composite springs, which (if STC-PMA approved) will deliver several very useful benefits in weight savings, maintenance, corrosion, resistance to yield/breakage and longer service life. Even better than the 180 tailwheel stinger.
We'll eventually be doing FAA drop tests and all sorts of official mayhem. But to keep the cost of this down (for me and for the customers), I need to get pretty close on paper before I start writing checks for the "official" testing.
What I need is to get the tail weight of a 170B at GROSS WEIGHT in the 3 point attitude. Not empty weight, gross. This of course will allow me to burn up some calculator batteries and figure out reasonably close approximates of the correct spring rates, and thus determine the spring dimension and material requirements in composite. Then the actual FAA testing can be done once or twice, instead of five or six times and breaking parts in front of the feds.
Thank you sincerely in advance for providing me with an accurate tail weight to streamline this process for me.
