Hey guys i was wondering if anyone knows what direction to look for the stc for the 470 in a 175
Thanks
Tom
Jaerl wrote:Follow this link and then put in the make and model of your plane. It lists all STC's available for your plane.
http://www.airweb.faa.gov/Regulatory_an ... enFrameSet
Brian - Steve's Aircraft wrote:Tom
We have done 2 470 conversions on 175's and I can look up the info for you in my shop on Monday. But, IMHO I would not do that conversion. I would do a 0-360 and lighten up the airframe as much as I could. The 175 does not have enough trim for the 470 and you have to put lead on the tail for the CG. Even at that it is still nose heavy. The 360 is much better in that sense.
Brian
EZFlap wrote:......If you just HAVE to have 6 cylinders, think about the O-540. I understand it is a lot lighter than the 470......
EZFlap wrote:I have to throw my hat into the ring here... the O-360 is probably a much better candidate for that airplane than a 470. I have not flown the 175, so I cannot say with any authority, but I would also strongly suspect that the extra nose-heaviness and lack of trim authority would take away a lot of the benefits that the extra power would give you.
You would likely wind up with an airplane that was not "balanced" both from a CG perspective and a flight handling perspective. I'm sure the (real, actual, experienced) back country Cessna experts will agree that poor handling, nose-heaviness, and flying around with full pitch trim makes for a not-so-good bushplane. When you are actually out in the boonies doing the nasty, you need a good handling, easy flying airplane in order to actually make use of whatever raw performance or raw power you may have.
What I will guarantee you from personal experience is that you will never get the best performance out of the airframe if you are flying at or near the forward CG limit. No way, no how, no chance. The best performance and handling usually comes in at or near the rear end of the CG envelope. This is a well-known, long-established tenet of aircraft performance. Ask any test pilot.
It's kind of like those sportscar conversions where you put a big block Chevy into a Triumph TR6 or the Sunbeam Tiger. You get a straight-line dragster with an incredible 0-60 and 1/4 mile time, but the first time you take it out on a real road you have a car that handles like crap. So you put these huge tires on it, and it finally will go around a corner a little better, but then you need power steering (the trimmable stabilizer that has already been brought up). In this case, you cannot put the power steering on (it would be a very big/expensive project to STC the trimmable tail onto a fixed-tail Cessna).
Another thing to consider is that you can get an O-360 to put out 200-210 HP without too much fuss and without losing any reliability. There was a "stock 200HP" version of the O-360 engine I believe. The STC tuned exhaust systems will give you back a solid chunk of actual power to the propeller that you otherwise had lost with a stock exhaust. A low-restriction intake air filter gives you back a little. There is "porting and polishing" that can be done legally, I think several engine shops have authorization for it. There are propellers available that deliver a little better thrust. I believe there are STC approved "electronic" ignition units that give you some increase in output as well as a touch better fuel burn. All of these upgrades cost some amount of money and/or time to get field approved... but the 470 conversion will also cost a lot.
Once again I cannot speak from personal experience, but I am willing to bet that a 200-210 horse O-360 conversion on a 175 would be a better all-around airplane and with better all-considered performance than a 230 horse 470 conversion.
If you just HAVE to have 6 cylinders, think about the O-540. I understand it is a lot lighter than the 470. You can lighten it up further by using lightweight starters and alternators. For what it's worth, you should probably fly in a 470 conversion before you embark on that project, IMHO.
