My plane is a '56 180 with an interav alternator. I do not however, have a separate alternator field switch in my panel - it has just a breaker which is actually kind of hard to pull out due to the side panel. I'm trying to educate myself about whether I need the newer split master switch (cessna added it in '73 as I understand it). It allows you to individually turn off the alternator field.
What are the benefits of retrofitting this switch if any?
I may have found the answer to my questions - I'm just looking for validation that I need to investigate this and have my plane retrofitted. Is it to improve the longevity of my charging system (to allow starting with the alternator field disconnected)? Page 14 of this article seems to claim this is not necessary.
http://www.aeroelectric.com/articles/Alternators/Know_Your_Charging_System.pdf
Here's the switch for cessnas:
https://www.aircraftspruce.com/catalog/elpages/cessnasplit.php?clickkey=87446
And a wiring diagram:
http://www.steinair.com/wp-content/uploads/2016/03/CESSNA-SPLIT-MASTER-SWITCH-DWG.pdf
