onefitty wrote:
I forget where I got the rivets though, I think they were DD's..
WHOA THERE ! This might accidentally kill someone who does not spot this typographic error.
DD rivets are the SOFTEST of all aviation rivets, essentially 1100 series aluminum. I'm guessing you mean "AD" rivets, which are 2117 alloy if memory serves, which are the far stronger standard airframe rivet. However, I might also be wrong, the Cessna specification may call for a special alloy or special rivet other than AD (or DD). With something that is this flight-critical, you simply must check the Cessna manual and find out what they are calling for.
Further, if you have loose rivets on any of the four strut fittings, safety and sanity demand that you remove the fitting and check for cracks or worn holes in the machined fitting and the strut tube.
There are real live engineers on this forum (I'm not), and on behalf of all of us I sincerely ask that they chime in here and make any corrections to what I've said. I also believe that wearing out those huge rivets means that someone has been dangerously abusing an airframe, and that a lot of other things should be looked into. If the Cessna manual actually calls for DD rivets, then I'm scared shitless right about now.
onefitty wrote:A vague reference on a forum is not considered acceptable technical data!!
onefitty wrote:
Sooooo.... You're doing major mods to aircraft and not really aware of the differences in fasteners...![]()
Just joking, no offense meant!
onefitty wrote:Not because of a strength issue, we simply can't drive an AD rivet of the required length without damaging the spar straps.
onefitty wrote:
Does that mean every bolt must have a drilled and lockwired (with copper) head, a retainer riveted over the head, a copper tab washer under the head, a cotter-pinned castellated fibre lock nut and then finally peen the whitworth thread...? I look after a few British planes...![]()
