A1skinner, a friend of mine put the Alaska Bushwheel equivalent of Cleveland kit 199-62 on his P model 182. He is running 8.00 tires but wanted to replace the three piece McCauley wheels and brakes and wanted to upgrade to double piston brakes. To make it legal he had to use the FA Dodge STC which lets you install kit 199-62 or -62 on 150's through 180's, 182's, 185's and maybe 205 and 206 but you would have to check. If you ask Alaska Bushwheel they will say they don't know anything about the FA Dodge STC but I had a copy of the STC from installing the kit on my 170B and verified the 182P was listed on the AML. I am fairly certain that he was able to use the anchor plate that came with the kit but could verify that if need be. Hope this helps.
