Anyone got any ideas for catching the fuel from the belly fuel drain on a c182 while on floats? I'd really like to avoid dumping the fuel in the water
Garth
nofate wrote:Unless you hold somekind of large pan under the sump drain its going to be hard to avoid getting fuel in the water. The fuel stays on top of the water and evaporates quickly though. The fuel sample from the wing sumps can be thrown on the float tops or dock to evaporate.
.gear wrote:Anyone got any ideas for catching the fuel from the belly fuel drain on a c182 while on floats? I'd really like to avoid dumping the fuel in the water
Garth
low rider wrote:I think he means that it's hard to catch it when you are inside the cockpit pulling the drain knob?
On the 182, you drain the belly sump by pulling a handle near the oil dipstick on the side of the cowl.
steve wrote:Same setup in my 185 Garth, no answer, it just goes in the water. Off topic, but did you get the float issue figured out?
Steve
