bumper wrote:Continentals take their cylinders half way to TBO, and Lycomings will spall their cams if you let them sit idle or wear their valve guides if you run 'em too hot. So how come we don't have a nice motor from Toyota or Honda, or a good USA made engine using up-to-date technology? Oh . . . wait, forgot . . . we have the FAA and their multi-million dollar certification programs to make sure we fly "reliably" with 65 year old designs.
Nope, not if you run them right they don't. In the case of the Continental IO 550, we had all kinds of trouble with them initially, but Continental changed the cylinder design a little, and some folks learned how to run them. I ran one to 1400 hours without touching it. Another pilot put 25 hours on it, and we had to change a cylinder. Duh. I ran it lean of peak all the time, but at LOW power settings. That engine went to tbo with five of its original cylinders.
The biggest problem with the IO 550 is that pilots try to run them at the same rpm/mp settings as an IO 520, and that means you are running a LOT of power. The factory says NO leaning above 70 or 75 % power, I don't recall which. Every pilot I visited with that complained about these engines was running 24 squared, which is a lot of power on the 550.
I'd run a 550 again any day.
In answer to the question, however, there is only one STC for a Lycoming engine on a 206, and that was for a TIO 540 conversion--MEGA expensive, very heavy, but lots of power.
Get a late model 550, get a good set of power charts, and abide carefully by the manufacturer's recommendations and I think you'll have good things to say about the 550. They have a lot of power, and they can last.
If your 550 vibrates, maybe you should get the engine/prop dynamic balanced, or get a new prop....
