Cessna Monarch Fuel Cap Screws?
On our 58' 180, the screws that hold the Monarch Caps on are getting a tiny bit rusted, and we figure we better replace them before there stuck for good, however I haven't been able to find hardly any information on how exactly these caps attach, what the screws go into, and overall how much of a pain in the ass it is to change the screws. Any and all information on this is greatly appreciated!
RKTX offline
145
- Aircraft: 47' PA-11
58' C180
Thu Nov 26, 2015 10:38 pm
Replace with 1/4-28 stainless screws. Inner ring attached to the fuel bladder. Outer ring attached to the wing.
Get a 1/4-28 bolt about 3-4 inches long to help you get the bladder screws started.
It is an easy job. Be real careful removing old screws otherwise you will be drilling and removing them with an easy out.
Rich
rfinkle offline
334
- FindMeSpot URL: http://share.findmespot.com/shared/face ... gujelTKUbh
Thu Nov 26, 2015 11:19 pm
http://apexbits.com/apex-phillips-head- ... -ribs.aspxBuy some serrated APEX Bits. I found the link above, but there are many choices. I'm sure the knowledge exists in this group to choose exactly which one is best. Use them in a high quality impact driver for the best effect. Use non serrated for reinstallation.
Cadmium plated steel screws are stronger than stainless, and will not cam out as easily. Just paint them to match. If the plating starts to thin in a decade or two, just change them again. If you're operating in the ocean then OK, use stainless.
Pinecone offline
996
- Aircraft: Cessna A185F
Fri Nov 27, 2015 10:51 am
rfinkle wrote: Replace with 1/4-28 stainless screws. Inner ring attached to the fuel bladder. Outer ring attached to the wing. Get a 1/4-28 bolt about 3-4 inches long to help you get the bladder screws started.
If you replace the screws one at a time, you shouldn't need the bolt. You also won't have to re-seal between the bladder & the inner ring.
10534
