Backcountry Pilot • Cessna SK185-27
Cessna SK185-27
16 postsPage 1 of 1
Cessna SK185-27
I just installed the SK185-27 (jackscrew inspection panel) in an A185F. I am sending Zzz the PDF of the install instructions if anyone is interested. Hopefully he can add it to the database. Nice mod and very useful.
www.avthreads.com
Re: Cessna SK185-27
Added to the Skywagon documents section:
https://backcountrypilot.org/knowledge- ... umentation
Re: Cessna SK185-27
Bigrenna wrote:I just installed the SK185-27 (jackscrew inspection panel) in an A185F. I am sending Zzz the PDF of the install instructions if anyone is interested. Hopefully he can add it to the database. Nice mod and very useful.
Very nice! Thanks Bigrenna.
Do you have photos of the installation?
Is it just for inspection, or does this access point allow for complete removal of the jack screws without pulling the vertical and horizontal stabilizers?
Scolopax offline
Re: Cessna SK185-27
You can remove the jackscrews, but you wouldn’t be able to rig them, at least using the service manual method, as it requires measuring 4.37” between a drill rod thru both actuators and the base of the stab up-block.
jrc111 offline
Re: Cessna SK185-27
jrc111 wrote:You can remove the jackscrews, but you wouldn’t be able to rig them, at least using the service manual method, as it requires measuring 4.37” between a drill rod thru both actuators and the base of the stab up-block.
I think the '63 SM has a different procedure, done with the horizontal on.
Re: Cessna SK185-27
You are correct! The 1963 to 1977 SM’s, and maybe later (I don’t have any later SM’s) does describe such a procedure. Pretty challenging from below only, I suspect.
jrc111 offline
Re: Cessna SK185-27
You can rig through this panel fairly easily if you understand what the rigging guidance is trying to accomplish. Sometimes you need to read between the lines to figure out Cessna's end goal. In the case of rigging this trim system. you need to make sure that you are hitting the up (nose down) stop at with just a little (1-2 links) of chain travel left. If you've got that, the down (nose up) travel pretty much takes care of itself.
AEROPOD offline
Re: Cessna SK185-27
What I found difficult was getting the links threaded correctly on the left actuator sprocket and the correct links between the two actuators without turning the sprocket while trying to get the chain guard secured in place:
https://backcountrypilot.org/community/ ... 9?start=40
jrc111 offline
Re: Cessna SK185-27
Thanks for this Greg.
Flying Dave offline
Aircraft: Aviat Husky
Re: Cessna SK185-27
Where did you get the kit? I can't find one.
Eddie
lefoy84 offline
Re: Cessna SK185-27
jrc111 offline
Re: Cessna SK185-27
Just talked to them. Textron has two scheduled for production in September. "TWO" YGBSM! Can't find anyone who has one in stock.
lefoy84 wrote:Where did you get the kit? I can't find one.
Eddie
lefoy84 offline
Re: Cessna SK185-27
I think you forgot an F in that acronym, but that may be the former Marine in me!
jrc111 offline
Re: Cessna SK185-27
AK-HUNT offline
Re: Cessna SK185-27
jrc111 wrote:https://cessnadirect.com/product-search/?brand=all&query=sk185-27
I contacted Yingling aviation today and spoke with Rebecca. She said the wait time from Cessna is 12 months. I brought up the idea that if there were several people interested in having this part made they may assign a higher priority and give a better price and get it done faster. Maybe there are enough of us interested to consider this.
Dog is my Copilot offline
Aircraft: 1958 Cessna 180A
Re: Cessna SK185-27
Ive got an old Univair price book from 2008, those kits were $145.
16 postsPage 1 of 1
