Backcountry Pilot • Cessna spring gear brake line protector
31 postsPage 2 of 21, 2
Re: Cessna spring gear brake line protector
I have a 1967 Cessna 180H with stock landing gear and wheels that I would like to replace the brake lines on. Does anyone have a list of fittings and Aeroquip hose length that works well with this MLG/wheel/brake installation?
Scolopax offline
Rob wrote:I believe this is what you are looking for. It is the brake line channel for a C-206, and in a 206 it is shorter than you'd like, so get it to your length. I got this tip from another site, and will use it on my 180 at paint. Very clean, very functional, and as protected as you're gonna get.
Take care, Rob
Rob,
I recently saw this plane in person. The entire thing is immaculate and very thoughtfully detailed. The only reservation I had about the brake line channel was that it would interfere with the way I jack up the gear for ski change-overs. But I suppose if you have a plane this nice, you probably also have a hangar and an overhead hoist.
-DP
I had done this to my C170. It did look cool, but as mentioned, was a real pain in the arse to jack the aircraft. Also, adhesive was a bit of a pain. Never tried dbl stick tape like Rob mentioned. Im debating on doing it again on the Skywagon project.
www.avthreads.com
bigrenna wrote:I had done this to my C170. It did look cool, but as mentioned, was a real pain in the arse to jack the aircraft. Also, adhesive was a bit of a pain. Never tried dbl stick tape like Rob mentioned. Im debating on doing it again on the Skywagon project.
shoe goo worked fine for me. Tip compliments of ezflap
http://eclecticproducts.com/shoegoo.htm
Glidergeek offline
Aircraft: 1968 P206C
DG 400
How would you jack your 180/185 with the rubber brake line extrusion? Seems like it would be difficult to clamp a gear leg adapter with that rubber on the back edge.
midwestskywagon offline
Aircraft: C180H
I use that white rubber channel, however instead of gluing it i simply attached it with two zip ties. Even though the gear leg is tapered the zip ties with the stainless locks hold well and stay put. If you carefully shape the brake line to the same arch as the gear leg and use white zips, it looks ok. At least then you can snip the zip ties and slip the jack pad between the rubber channel and the gear leg when you need to jack the plane.
On The Fly offline
Aircraft: C`182K
Place the jack under the ski axle? :D
Pinecone offline
midwestskywagon wrote:How would you jack your 180/185 with the rubber brake line extrusion? Seems like it would be difficult to clamp a gear leg adapter with that rubber on the back edge.
In today's day and age, a gear clamp adapter is a poor choice for jacking at best, a hazardous one to both the mechanic and aircraft at worst. Either of these, or better yet lifting rings would be much better choices.
Any of these choices allow for the aircraft to wiggle and move with no risk, allows for oops bumps without risk, and allows for jacking with a brake line protector in place.
Take care, Rob
Rob offline
Wow, that's a pretty burly spreader bar!
Rob wrote:
Is that tube (bolted to gear leg) the standard tube for ski's or is that made for that jack?
I'm putting these same brake line channels on my gears and I was thinking of using something like this for jacking up the gear.
corefile offline
Aircraft: Cessna 180 - sold
There have been several home-brewed versions of these. This one was from a member, I just pirated the picture to illustrate a better way to safely Jacking a Cessna :D
https://backcountrypilot.org/forum/quic ... ick%20jack
Rob offline
