born2flyak wrote:Well, I've never used the EZ flap handle in any aircraft yet, but if it's easy to reach the flap handle to pull in the first 10 or 20 degrees of flaps, what next? The EZ flap handle is now at the OEM handle's 40 degree angle, it looks as though you need a flight engineer in the backseat to pull in the last 2 notches...and I really am ignorant, never used it, and don't make landings without full flaps, unless flying bored and empty on long runways...
Because of the Cessna flap system's long lever and long 80 degree throw, there is no one place where you could grab the flap handle and use it comfortably in all four positions. Whether you grab it using the stock handle, or grab it by an extension device, one or the other grip is either too far forward or too far back. It's like the steering wheel in your car. Ford and Chevy decided to design your car so you just can't really do it without switching your hand grip three or four times to get the entire steering travel out of it.
Fortunately on the flap handle extension, you only need to switch grip once.
On a Cessna, you use the extension to grab the flaps at the zero position, easily while you're sitting upright. When you get to 20 degrees, the stock Cessna flap handle is now (finally) in the right position for you to grab it... so you use the Cessna handle to get into the 30 and 40 degree positions. At those positions, the extension swings back out of the way under your elbow. NO, it does not hit the seat, NO it does not hit the pilot. (On a Piper, which uses a much shorter throw and a shorter flap lever, you don't switch grips)
The next question most people have is... "...but it looks like it will be kind of clumsy and time consuming to "dump" the flaps off on a STOL landing in my 180...?" I've timed it with a stopwatch. It takes exactly HALF a second to dump off the first 20 degrees of flap, switch your grip back to the EZ Flap handle, and dump off the last 20 degrees. In return for that half-second of time, you get to sit upright, watch where you're going, not accidentally lean on the right rudder pedal, and keep 100% situational awareness of your LZ.
You're not ignorant at all, you're just coming up with the same questions and the same concerns that the FAA had a year ago. These are the same "problems" that (first) I had to make sure did not actually exist, and (second) had to convince the feds that the problems didn't exist, and (third) that I now have to convince the pilots that these problems don't exist. Normally I'd say "Trust me, I solved all those problems" but nobody wants to trust a guy from Hollywood
To prevent this reply from becoming commercial, see the link below for info on who stands behind what and how.
