I'm sure some of you might have seen this, but first for me!!
Couple of you guys are Helo pilots, I have a little time in them, but this is pretty wild!!
contactflying wrote:Crazyvan13 is correct on the models. The CH-46 had a lot of issues so the Marines, of course, ended up with it. We got the better CH-47.
The demonstration was an excellent display of pilot technique , crew coordination, and stupidity. If I had been in the crowd, I would have been the one leaving rapidly at a ninety degree angle.
asadarnell wrote:This also makes me very interested in the flight controls of a tandem rotor helicopter versus a standard single rotor.
tcj wrote:It would be interesting to see a video from inside of the pilot's motion while they are flying. Must be some wild control movement to turn like that.
contactflying wrote:Cameron,
I was looking at weight, inertia, and missile damage. Blade strike, two big three bladed rotors breaking into hundreds of lethal missiles in a roll over : big body count. Where does the transmission go in a twin rotor blade strike?
The helicopter is the most dangerous military vehicle with respect to those on the ground.
CamTom12 wrote:tcj wrote:It would be interesting to see a video from inside of the pilot's motion while they are flying. Must be some wild control movement to turn like that.
That's a big misconception from fixed wing pilots. My primary aircraft was the OH-58D. We'd make that aircraft dance with cyclic inputs that never exceeded ~2-3 inches from center. Collective inputs around 4-5 inches, and pedal inputs were usually around 1 to 2 inches from neutral in forward flight (hovering is another matter, depending on the winds and how proactive you are with corrections).
I've flown the Chinook and currently fly a lot of Blackhawks. Control input ranges are pretty similar in those airframes as well.
would much rather take my chances in a CH-46 than an Osprey
You can see our other helo on rear deck of Sacramental in the middle. Not to mention the Battleship
They said every time they fired a broad side the ship would move 12 feet in opposite direction
akaviator wrote:Very cool, thanks for sharing.
The Chinook is an absolute ageless beast of a helicopter. I have a friend who rescued stranded climbers on Mt. McKinley at 18200 feet with one and had a lot of praise for the capabilities of the ship. He actually made two trips on back to back days and was named Army Aviator of the Year.
