STC SA63GL
A1Skinner wrote:Is there a separate STC fir very tire size Greg? I find it interesting that they specify only 8.00x6s.
Awesome. Thanks.Bigrenna wrote:A1Skinner wrote:Is there a separate STC fir very tire size Greg? I find it interesting that they specify only 8.00x6s.
The STC was so old that 8.00x6 were considered huge tires. LOL
This will get the brakes on. The STC for 8.5x6 or bigger would be separate.
A1Skinner wrote:Awesome. Thanks.Bigrenna wrote:A1Skinner wrote:Is there a separate STC fir very tire size Greg? I find it interesting that they specify only 8.00x6s.
hotrod180 wrote:and I've never seen a 4-ply 850x6 tire.
BirdyinBOI wrote:...to put on the ‘58 182 I’m purchasing. I want to use 8.00x6 tires. Do I need an STC for the brakes and/or the tires?
Phil
Do you have spacers Marty? I needed spacers on both my Citabria and my 180 when I went to 31s.180Marty wrote:Speaking of tire/brake interference, I have double puck Clevelands on my 54 180 and afraid when I put new brake linings on, they are going to rub my 29 inch Bushwheels.
VTOSS wrote:Bigrenna thanks for the great info, I just ordered our CD!
Our 1956 182 has 8.50x6 with single puck Clevlands on a 337 Field Approval from the 80’s. The Field Approval includes the Mains and Nose Tires and 206 Nose Fork. One of my overall goals with the airplane is to clean everything up including paperwork as we go. It does have excellent records complete back to day one. However as we complete additional modifications I want to keep things neat and clean. I am chasing a couple of issues right now and looking for some help;
1. The current configuration allows the tire sidewall to contact the brake caliper if the tire pressure is only a few PSI low and there is any flex and/or side load. Is there any reference to shimming that can help with this? I have read the article suggesting calling Alaska Bushwheel but have not called them because there shims are for 206/207. Although we just purchased the airplane, I have been around it for 20+ years and this is a new issue. My concern is when the brake pads were replaced at the last Annual something like a shim or spacer was left off.
2. I want to upgrade to a Double Puck but don’t want to chase STC’s around with the Field Approval. Currently it has Clevland Wheels and Goodyear 8.50’s. Is it possible to upgrade the brakes without having to match to a wheel and tire STC? If I can find a nice set of used brakes can they be Field Approved? Anyone have a set? Do the Double Puck use the same rotor as a Single? Also, I am not opposed to purchasing an STC that matches the Field Approval, I don’t know how that changed a Field Approval when the STC may only covers a portion of the FA.
Well that got a bit long winded but it’s what I am dealing with… Thanks for any input.
VTOSS wrote:Well I called Airframes Alaska and they were excellent as usual. They share the same concern regarding the nose fork, wheels and tires being on the same 337. I also have the original 337 for just the nose fork and the narrative in the second 337 acknowledges it as follows;
Previous installed large tires on aircraft. Main tire 8.50x6 6ply, nose tire 7.00x6 6ply. Inspected installation wheels, wheel halfs, bearings and axle, brake system. Inspected installation of larger nose gear fork found on 337 dated 06-02-1994 Found to be working correctly and installed properly. Aircraft apparently has been in service since 06-02-1994 with these tire and wheels. Updated weight and balance.
I did get a copy of the Atlee Dodge STC and will look it over tonight. It's too bad the Free STC above doesn't include the 182 even though the gear is the same as the 180 on my 1956.
If I purchase the Atlee Dodge STC and new ABI Brakes and Wheels, I would assume it will supersede this 337, the nose gear will still be covered under the original 337 and all should be legal and good. Or am I overlooking anything?
