Backcountry Pilot • Cleveland wheels from a C182P 1973 fit a C172M? 1973??
5 postsPage 1 of 1
Cleveland main wheels of a Cessna 182 P year 1973, will they fit into a Cessna 172M year 1973?
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: Cleveland wheels from a C182P 1973 fit a C172M? 1973??
Will they fit is one thing, are they applicable is a very different thing. I would suggest, if you already have not, mosey over to the Parker webpage where they have a list of part number and what they apply to. Sometimes you need to drill into their STC's and what is applicable that way. Wheel rims can be the same over several different configurations, many times it is the brake disks that differentiate the kit for one aircraft from another. Other times, lets say on my floats, the rims are identical to others, except they have drain holes to let that pesky water out and accommodate the spacer that keeps the ever so sticky grease around the bearings and water out.
dogpilot offline
Took ball and went home
jcadwell offline
Thanks for posting that McFarlane catalog link.
Thank you this worked.
motoadve offline
CJ 6 Nanchang
Cessna 170B
5 postsPage 1 of 1
