G44 wrote:Jughead, after you cleared the lip of the cliff you should have dumped the flaps as you pushed the nose over, that would have given you a thrill for sure!
Mapleflt wrote:G44 wrote:Jughead, after you cleared the lip of the cliff you should have dumped the flaps as you pushed the nose over, that would have given you a thrill for sure!
Yes; but then all the cool kids would try it at home.He's trying to set an example after all; a pillar of how to play safe and have fun, for all to follow.
Your a model aviator Jughead, leading by example.
The BCP community needs more like you to lead us down the path of aviation righteousness, keep the faith Sir.
jugheadF15 wrote:Mapleflt wrote:G44 wrote:Jughead, after you cleared the lip of the cliff you should have dumped the flaps as you pushed the nose over, that would have given you a thrill for sure!
Thanks Maplefit. G44, to be honest the airplane was flying at the edge on its own. With the 15kt updraft under me at the edge, I could have climbed pretty aggresively. I have some other spots selected where I will go off the edge at less than flying speed and have some fun.
aftCG wrote:Should have called this one "Jughead finds a much deeper ditch"
