Backcountry Pilot • Com Radio: 5-10-16 Watts? How Much, Why, When, & Where?
12 postsPage 1 of 1
I have been staring at com radios ( again :D ) and got to thinking about the power output. Obviously at VHF frequencies much is line of sight, and antennas, antenna placement, impedance matching, coax feed loss, etc are all factors. However... All things being equal.. what power levels did you choose for what kinds of conditions and missions ? (VFR). What kind of aircraft and where is the antenna or antennas if diversity reception ? Would you still choose the same or recommend otherwise?
Here are a few examples of what's out there these days ( March 2014 ) for panel mount Com Radios.
PS Engineering PAR100EX - 5 Watts
Icom IC-A210 - 8 watts
Garmin GTR200 - 10 watts
Garmin GNC255 - 16 watts
Denali offline
Re: Com Radio: 5-10-16 Watts? How Much, Why, When, & Where
Just get the lowest power one...I don't need to hear you making radio calls here on the west coast :mrgreen:
bart offline
Aircraft: Cessna 180
I do not know what the power output is in my radios but I would like enough power to reach ATC when out over the northern central Nevada. There have been several times when Salt Lake would either not hear me or just ignored me but a couple of times a high flying commercial relayed my needs. Usually checking if MOAs were active and the chart said to call Cowboy on xxx,xx. Maybe a little more power would have helped, not sure. I know I used to have 600 watts available on my old IH Scout and it helped save a couple of lives when the for or five watt limit could not get beyond my front bumper. Like horsepower, it is hard to have too much.
If it is a new purchase, why leave the option behind on the avionics shop shelf.
I have also flown the Alcan in an old 39 J5 with a small hand held - often I could hear them but they could not hear me so the just told me to expect the light signals.
Chris C
wannabe offline
53 C-170-B+
As a ham I would say the antenna and tuning is more important than the wattage. I'd rather have a 5 watt radio with a great antenna than a 100 watt radio with a poor antenna. You can do some amazing distances with 5 watts.
scottf offline
@scottF :
Agreed. As a ham radio operator myself I will even go so far as to cut the right length of coax and make sure it resonates with the frequencies used and the Q characteristic of the antenna, But still, it begs the question, what levels of power are perhaps too low or marginal, vs too much power.
For aviation, I am thinking, at least for me, the sweet spot is 10 watts. Garmin has a nice 10 watt unit that's affordable, easy to read, and small in size. 5 watts might be marginal, and 16 watts costs a lot more, and may be overkill. I'll keep a 5 watt handheld for back up. Incidentally, the CEO/Founder of PS Engineering in Tennessee is also a ham, Mark S. is W9MV.
The idea of using more than one antenna is something I am examining as well. Finally, on another website one of the discussions focused on proper mic distance and intelligibility. Bottom line, don't forget proper use of the mic.
Denali offline
I don't have much radio knowledge but I'll add my experience. In my Luscombe I have a handheld com radio (5 watt) wired to a standard external antenna mounted on top of the cabin. At altitude I have spoken with planes that were over 100sm away. I've never had trouble communicating with anyone because my radio was weak. My takeaway is that 5 watts is plenty when set up properly.
At VHF frequencies, power is not much of an issue, range depends mostly on your altitude and the terrain. a poor antenna installation will subtract a LOT of range, but anything over the standard 18" or so antenna will not add anything to it. I have talked 225 miles on a 5 watt radio from 10,000 feet over north Dakota, and well over 100 miles on a 1 watt handheld on more than 1 occasion.
Dale Moul offline
Dale
Gravity Strikes Again.
Whee, virtually ALL of the handhelds are 1.5 watt transmitter CARRIER power (the most meaningful rating for comm radios), with ~5 watt Peak Envelope Power (P.E.P.); most of the stated transmitter power of panel mounts is carrier. And all of the current crop of handheld brands are actually very good. Think of your handheld as a 1.5 watt unit.
Around my home aerodrome, there are three Luscombes with very good antenna installations (broadband, mounted in middle of turtledeck): a panel-mount KY-97A, an ICOM 200A (both nominal 5 watt carrier), and one with a handheld. From my office on the ground ~25 miles away, with a handheld/rubber duck antenna in the window, the two panel mounts sound as good as the 25 watt Kingairs and such at pattern altitude, and the handheld sounds better than 85% of the panel mounts of the single-engine fleet. Having a good mike, with mike gain matched to the radio makes quite a bit of difference too.
I would amend your comment to say that "1.5 watts of transmitter power with a good antenna is adequate for most purposes." Ummm soyAnarchisto, did you ever get your antenna stuff sorted out?
To the original post, it's probably better to figure out which features you want, and to select a brand and installer with a solid track record than to worry about the difference between 5 watts or 10 watts of power.
Thanks. cubscout
cubscout offline
I'll agree with all of the above, and make one additional comment. In clear weather, VHF line of site doesn't require much power at all, but precipitation, especially rain, will attenuate VHF signals. So if you anticipate flying in wet weather a lot, the higher power may be worth it.
The only time I've ever had a problem with my 1.5W hand held and remote antenna is talking to the tower while on the ground. I operate out of a satellite airport, and need to talk to a tower nearly 3 miles away. On the ground I can hear them just fine, but they can't hear me. Other aircraft in the area can though. And with the KX170B in my previous aircraft (5W?), it was about 50/50 whether or not they could hear me on the ground or not. As soon as I clear the trees they can hear me just fine though. So maybe a 10 watt system would help me get my signal through the trees a little better?
Bear_Builder offline
cubscout wrote:Whee, virtually ALL of the handhelds are 1.5 watt transmitter CARRIER power (the most meaningful rating for comm radios), with ~5 watt Peak Envelope Power (P.E.P.); most of the stated transmitter power of panel mounts is carrier. And all of the current crop of handheld brands are actually very good. Think of your handheld as a 1.5 watt unit.
Thanks. cubscout
I told you I didn't know anything about radios. :D Thanks for the lesson cubscout. I looked up the specs and cub is right 1.5watts, at least for my current handheld. So I guess the point is, as cubscout already stated, figure out which features you want in a radio and don't worry so much about the carrier power.
I know little about radios, either, so I rely on the experts. Good antenna and good connections trumps high power, every time, according to a client who is a radio expert and also according to my avionics installer. My avionics guy said 10 was plenty, when I had the 430W installed. I had the choice between 10 and 16 watts, and he said that unless I needed to communicate 200 miles away, I'd never notice the additional power--and it cost a few hundred more for the 16. All FWIW.
Another ham here. Sometimes, when the antenna connections are less than optimal, or your antenna is cut for the middle of the voice portion of the air band and you are transmitting at the edge, power can help you get through. But more importantly; the comment about precipitation, possible contact via reflection off terrain, or other attenuating circumstances will require more power.
One of the curious facts about our radios is that they operate in AM mode instead of FM. There is a reason for that. With an FM signal, the receiver has to provide the audio by interpreting modulations or changes in frequency. When something attenuates an FM signal big chunks drop out. It has a distinctive chop to it and becomes quickly unintelligible. An AM signal, as has been mentioned, has a carrier with a couple of sidebands that are modulated according to the width of the audio signal in a sum and difference offset on each side of the carrier frequency.
Ok, enough of that. What this means in a practical way is that when an AM signal is weak, something comes through. Power helps that. The FAA and FCC in their infinite wisdom could have changed the system to FM years ago. They didn't. For absolutely essential communication, in it's simplest form, AM works better.
Give me an old Com 120.
Mister701 offline
Aircraft: Rans S7LS
12 postsPage 1 of 1
