Backcountry Pilot • COMP AIR 8 Turbine ?
9 postsPage 1 of 1
Anyone has experience with this plane?
One pilot moving to Costa Rica is looking to buy one and bring it to fly our uninproved strips.
Either this or a turbine Cessna 210.
I recommended against the 210 and in favor of a Soloy Cessna 206 (The police has a couple of those here and are amazing)
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: COMP AIR 8 Turbine ?
If I remember correctly, they didn't have a great reputation as a bush plane as the wing is just not right (or something like that.)
I vote for the SOLOY 206, big time!
G44
Zzz wrote:If I remember correctly, they didn't have a great reputation as a bush plane as the wing is just not right (or something like that.)
Plus, they are made out of plastic or some sort of chemical brew :)
If it isn't made out of metal, it doesn't belong in the back country!
Tube and Fabric is the way to go. Monocogue (my current predicament) not near as good, plastic… good luck :)
Look into insurance. It might open your eyes.
237
SkyTruck offline
'80 A185F
Plus, I don't think you'd want to be flying around in what looks like a stretched-goose
Just for the looks alone I would never buy it, its very ugly.
motoadve offline
CJ 6 Nanchang
Cessna 170B
Like all the other responses, I have no direct experience with the Comp AIr. I did give a flight review to a Canadian Pilot who owned a Comp Air 6 with a piston engine. He had owned a C-185 previously. He said that the Comp Air was a better plane than the Cessna in every way. Land shorter, Take off shorter, fly fast for longer and haul more. He also said that the engineering specs the wings for a higher strength than a 185 as well. He also felt that it was a better handling aircraft than a 185. This may be like trying to sell the Harley crowd on the absolute superiority of a Honda motorcycle...it may be the truth, but impossible to accomplish.
Like I said....it is second hand info, but at least I was talking to the owner of the aircraft. He showed me a bunch of pictures that looked gorgeous and of the tiny strip he gets in and out of in BC. If I had the $ i might buy one (If I could fly it first, of course). I wouldn't worry too much about composite construction. 90% of boats made in the last 50 years are made of composites and they are subjected to much worse treatment than aircraft and seem to last just fine. Remember, this was a piston plane not a turbine.
littlewheelinback offline
I like the look of the 6 better:
Searching for a Comp Air 8-piston (which doesn't exist apparently) I ran across a lot of photos of the Comp Air 8 in a crumpled pile on the ground, most times on fire, like 5-6 different crashes in a 45 second Google search... yikes! :shock:
I flew a CompAir 6 that had that BIG Lyc IO-720. I thought it was a great plane! It had pretty docile stalling qualities and would haul ass (all things considered). The one I flew had VG's AND Stall Fences. It had good rudder authority. Kind of reminded me of a 185 on steroids.
jaudette offline
Aircraft: Husky A-1B
Vans RV-7a
9 postsPage 1 of 1
