Backcountry Pilot • Continental I0 470
Continental I0 470
21 postsPage 1 of 21, 2
Continental I0 470
Hello All
I need a Continental I0 470 S for my Cessna 210
Being on a fixed income of sorts, I am limited so does anyone know what letter suffixes also work?
I believe an I0 470 D can be modified
What about I0 470 C?
Or L, VO or M?
Can someone help please.
EJM offline
Aircraft: Cesna 210
Piper PA 28
Re: Continental I0 470
The TCDS explains the differences between the model # suffixes.
C180_guy offline
EJM wrote:Hello All
Or L, VO or M?
http://rkaplan.hypermart.net/C210%20Typ ... 20Data.pdf
akaviator offline
Aircraft: Cessna 180
Hi
Thanks but I have no clue what this is.
Please explain
EJM offline
Aircraft: Cesna 210
Piper PA 28
Might be worth calling an engine shop and asking them. A good shop should be willing to help you out, especially since they'll probably end up selling a few parts to change the designation...
EJM wrote:Hi
Please explain
Since you are the airplane owner, it would behoove you to go to faa.gov where for free you can download the TCDS for your airframe (posted by akaviator above), engine, etc. They have all the ADs posted and all kinds of other good stuff for your downloading pleasure.
C180_guy offline
C180_guy wrote:
EJM wrote:Hi
Please explain
The TCDS won't help him with the engine suffixes. For example, can you take a D model, change the pan, filler neck, induction and make it a S? Thats all engine info and the aircraft TCDS won't help with that. Sure it will tell you if you can use a certain suffix, but won't help him to convert an engine from one suffix to another, which if I understand his original post is what he is wondering.
Thanks guys
I'll call an engine shop.
Any additional info would be great.
I emailed TCM but it wasn't productive.
EJM offline
Aircraft: Cesna 210
Piper PA 28
EJM wrote:Thanks guys
Sorry I don't have a better answer for you. I could help with 520s as I went through a similar thing a few months ago on them, but don't know the IO 470 as well.
Engines and propellers have TCDS (Type Certificate Data Sheets) also. They show the differences between models on the same Type Certificate in the notes.
bat443 offline
bat443 wrote:Engines and propellers have TCDS (Type Certificate Data Sheets) also. They show the differences between models on the same Type Certificate in the notes.
Here's a link. https://rgl.faa.gov/Regulatory_and_Guid ... enDocument
Should be able to use a D, E, or M if your intake is good from your current S.
It doesn't show all the differences. I opened the IO 520 one and it does list some differences, but not all of them. This is where an engine shop would come in handy to fill in the blanks such as oil pan difference or oil fill tube differences.
If he needs more info on the model suffixes than what the TCDS note provides, simply look in the Continental IPC and compare the effectivity codes. The OP is the airplane owner and he should have copies of the IPCs. If not, they are not expensive. Textron allows free pdf download for the airframe and I Continental does something similar.
C180_guy offline
EJM wrote:Hi
Please explain
It's the type certificate data sheet. The original approved engine(s) are in there. If you can't read it, I'm sure your mechanic can.
akaviator offline
So I saw a 210B a while ago that had a I0 520 in it but I couldn't find an STC
It seems an I0 520 would be a better engine and make it a better airplane with a longer TBO
Thoughts?
EJM offline
Aircraft: Cesna 210
Piper PA 28
Thoughts?
I think that would he a great way to go, and I think a 520 may be easier to get your hands on. You will most likely need to do a field approval though. I think there's a guy on here that has done the field approval onto a 210/5(205), but that might help you get approval for your 210.
EJM wrote:......I need a Continental I0 470 S for my Cessna 210.....
You never said why you need an engine.
Is your 210 without an engine?
Did you blow the engine that's in there?
Etc?
Converting another model of IO470 is fine,
but it might be cheaper & easier to just fix what you have--
esp if it involves tearing down the different engine,
and/or significant paperwork
Etc?
So.........
The saying goes "there are those that have and those that will"....... experience engine failure.
I landed on a road with a hole in the side of my engine and oil all over my windscreen.
Thanks be to God Almighty for guiding me safely down.
(I have nothing to rebuild)
EJM offline
Aircraft: Cesna 210
Piper PA 28
Etc?
So.........
EJM offline
Aircraft: Cesna 210
Piper PA 28
I had the same thing happen to me in my old C170--
broke a connecting rod, punched a hole in the case.
A major overhaul, replacing the case, rods, & cam,
and I was back in business.
Even just a data plate can be overhauled.
hotrod180 wrote:I had the same thing happen to me in my old C170--
Roger that,
if you have enough money
Maybe like the guy that claimed to have the axe George Washington used to chop down the cherry tree,
I only has seven new handles and three new heads :D
EJM offline
Aircraft: Cesna 210
Piper PA 28
