contactflying wrote:They were engine dependent and dangerous.
contactflying wrote:Courierguy,
I have found what you said to be true, over the years. I have trained many crop dusters and known many older ones who would make excellent instructors. They just never express the stuff they know.
Good maneuvering flight techniques are common sense. The problem is they have been taboo for long enough that many who know are unwilling to say. The FAA, who bears responsibility for training, considers we who know as "Those of whom we do not speak."
The guys in the video knew well what they were doing. Putting the wing down near the ground make exciting viewing and they knew they had the power to risk it. What irks me, as an instructor, is that it is a poor example. There are those with little engines that might try the same and mush into a cartwheel when terrain and perhaps a downwind reaches out to bite them. The airplane, as the big boys say, doesn't care which way the wind is. When low and encountering terrain at much faster ground speed than he wishes, the pilot does. The airplane can in no way stall itself. The pilot can. Rather than hit the terrain or obstruction in a steep turn with a down wind pushing him toward it faster, he will pull back on the stick. Any of us would. The trick is to pull back on the stick wings level while at cruise to trade airspeed for altitude. The slower we go, the faster we turn. The faster we go, the slower we turn. That altitude can be exchanged for gravity thrust simply by allowing the nose to go down when we turn. It just takes situational (outside) awareness and staying ahead of the airplane and allowing the airplane to help you make the turn. No bank is too steep unless you pull back on the stick in the turn. Pull back before the turn.
These guys are going to get after you. You got me going.
Contact
contactflying wrote:No bank is too steep unless you pull back on the stick in the turn. Pull back before the turn.
