Crankshaft inspection
I am doing a prop strike inspection on a O-300 engine and was wondering if anyone new of a good shop to do the inspection on the crankshaft. What I am most concerned about is a honest shop. I have gotten parts failed by shops, that I was very suspicious of their motives.
cfimechanic offline
54
Tue Jan 01, 2013 11:08 am
Call Joe at Aircraft Cylinders & Engines at Greeley. If he can't do it, he'll know who can--he's one of the best engine guys in this area, totally honest.
3801
Tue Jan 01, 2013 12:11 pm
There are a few shops that just do the NDT, they have no gain one way or another. We do a ton of prop strike inspections at the shop, due to the number of gear up aircraft we fix a year. The cranks are not what fails, typically. We find more problems with the cam gear, mag drives and oil pump and its drive. These are what we usually end up having condemned.
dogpilot offline
- Took ball and went home
902
- Aircraft: Cessna 206H Amphib, Caravan 675 Amphib
Thanks for the input. I’m going to call aircraft engines and cylinders today and leave a message. If you have suggestions please leave me a specific contact or company name.
I have only sent one other crank out for inspection and everything was fine, until I told the shop it was a prop strike. Suddenly he could see the cracks with the naked eye. I have no proof that I was shamed so I won’t name the shop, but it just felt shady.
cfimechanic offline
54
You can try:
Graham Aircraft
(770) 252-4995
rick@grahamenginescom
-or-
Crankcase Services
Oklahoma
(877) 835-9274
I believe Kevin was the contact.
Toll Free (866) 276-6767 OR (918) 245-6767
FAX (918) 241-62
14700 W. Shell Creek Road, Sand Springs, OK 74063
dogpilot offline
902
The advertisement said "Crank dials OK". This means it is a crankshaft so smart, it has learned to dial the
918 area code on its own, where most of the crankshaft repair stations reside...
Thanks. cubscout
cubscout offline
151
