Reichy wrote:I remember reading briefly about this accident. Now that I'm in the middle this week of purchasing a '73 180J with regular crossover shoulder straps, I was thinking about putting in the B.A.S. system and was on the phone with Jim (B.A.S. owner) just this a.m.
Mike's account has me convinced and I'll get 'em in the plane. Thanks, Mike.
I wonder if there is a crotch strap STC'd for the 180/185 airframe? I'm thinking of the rotary buckle that already has the insert at the bottom for it.
R
mtv wrote:
I too think that a "negative G strap" (nicer word than "crotch") would be a good idea...
I really cinch up my lap belts. A lot of people in cars tend to submarine under the belt, and when it cinches up tight, it breaks their backs. The Huskys all have the five point harness, which I like, but it has a fixed seat.
G44 wrote:Get the Seaplane buckle that separates all belts when the buckle is lifted.
mtv wrote:G44 wrote:Get the Seaplane buckle that separates all belts when the buckle is lifted.
Actually, I've flown both a lot on floats, and I much prefer the "standard" buckle over the "seaplane" buckle. And I've worked seaplanes on some fast rivers with the standard buckles....in and out mucho quick. To egress you just roll out the door...very natural move and I've never got hung up on the harness.
Pinecone wrote:I agree that donning the standard harness is probably quicker if you're doing a lot of short cycle commercial work. I think I'd roll out of it easily too. Again, it's unaccustomed passengers and rescuers who might have trouble with it.
As for rear seat passengers, I believe it would be a slight nuisance, but not unmanageable. Buckle it up and tilt the front seats forward, and the belts will extend forward with the seat back, or even more if you have headrests.
Fraser Farmer wrote:I know the BAS harnesses are high on my to do list. I feel like the fixed harnesses are pretty useless in my 180. It's impossible to have the things tight enough to be useful and still be able to reach the flap handle.
albravo wrote:MTV,
Excellent post. Harrowing and illuminating at the same time.
A couple questions from someone that hopes he never needs to remember your answers:
1. Were you making mayday calls on the way down? If not, why not?
2. Prior to impact did you open your door and close the latch with the door open? In my forced approach training I've been taught it is one of the SOPs so that the door can't get jammed shut.
3. If the engine still worked, would Don Cogger and Atlee Dodge Jr. have flown it out on a salvage permit:-)?
Allan
mtv wrote:I told them that it appeared my work was done here for the day, so I'd like to go home.
mtv wrote:Fraser Farmer wrote:I know the BAS harnesses are high on my to do list. I feel like the fixed harnesses are pretty useless in my 180. It's impossible to have the things tight enough to be useful and still be able to reach the flap handle.
Agreed, and it's not just the flap handle. My Cub doesn't have flaps, and it has fixed harnesses. I cinch up my harness when I buckle up, but soon I find that having the harnesses tight is less than comfy, and tend to loosen them. Passengers seem to do the same.
It's hard to visualize just how "plastic" the human body becomes in a sudden deceleration....but snug harnesses are essential to survival.
Fraser Farmer wrote:mtv wrote:Fraser Farmer wrote:I know the BAS harnesses are high on my to do list. I feel like the fixed harnesses are pretty useless in my 180. It's impossible to have the things tight enough to be useful and still be able to reach the flap handle.
I've never been able to leave the fixed harnesses tight long enough for them to become uncomfortable so I didn't know about that. It was more like the first couple times I flew the plane I tightened them right up as I thought I should, only to immediately discover I couldn't operate the flaps and then they were never tightened again. Unfortunately the situations where you're closest to the ground and most likely to crash are also the situations where you need to use flaps.
I'm going to have to get some BAS harnesses sooner rather than later.
mtv wrote:A little post script:
It wasn't till later that one of the guys that works at that base told me "The Rest of the Story": The phones at the helibase ring out and conversations are broadcast over a loudspeaker over the base. The helibase foreman answers the phone, but the "ready" helicopter crew listens any time a call comes in, and depending on the nature of the call, they will literally be spooling the turbine before the phone is hung up. They'll pick up anything else they need via radio once airborne.
Well, turns out the helibase foreman answered the call from ATC, and informed them that Alaska Fire Service does not do Search and Rescue. ATC was telling him that the downed pilot (me) had specifically told him to call AFS.....etc. Apparently, the helibase foreman was getting his undies in a bit of a knot when the turbine whine of that 205 started to spool.....at which point, he started yelling at the pilot not to go. Pilot, of course, ignored him.
After this was all over, and I heard that part of the story, I tracked down the helo pilot and thanked him profusely, particularly since he didn't make any points with the helibase manager. His response: "No brainer....somebody calls and needs help, and I've got the key to a helicopter, and I'm not going????? Hardly." My kinda guy.
